Home > Maintenance & Mods (L322) > Sorry another IID question
Billydun34
Scotland 2010 Range Rover Vogue SE TDV8 Zermatt Silver
I am trying to reflash my bluetooth module with no luck, i have bought a new battery today and have a CTEK max 7.0 attached to the battery so everything is fully charged, then when i go to start the reflash i get a message saying the voltage is below 11.5v operation aborted.
Has anyone had the same problem while trying to reflash? or any pointers would be great.
Post #342670 15th Aug 2015 5:54pm
Weegie
If you bought the battery today I would give it 24 hrs on charge to ensure it is fully charged. If it has been on the shelf for a while it may have discharged a bit.
Also when you try to reflash have you turned everything else off - air con, screen, radio? John
GAP iiD BT-Sold
Post #342673 15th Aug 2015 6:43pm
Billydun34
Hi Weegie thanks for your reply. yes i had everything switched off just the ignition was on..
Post #342683 15th Aug 2015 8:02pm
Billydun34
Update.. Battery been on charge all night and is now fully charged but I'm still getting the voltage below 11.5v on the iid tool, when i go into the live values for the battery it is saying that the voltage is 12.9v Big Cry Big Cry Big Cry
Post #342758 16th Aug 2015 3:25pm
That's not good.... send Pat at Gap a message, they are very helpful.... Thumbs Up Pete
Post #342778 16th Aug 2015 5:49pm
Billydun34
Problem sorted, i re updated the firmware on the iid tool via the computer and tried again and it worked, i must have done something wrong when i first updated the tool!!!! Thumbs Up Thumbs Up
Post #342784 16th Aug 2015 6:19pm
