![]() | Home > In Car Electronics (L322) > after contact 12v & inside 12v |
Ibartsimp Member Since: 24 Dec 2012 Location: Bordeaux, France Posts: 197 ![]() ![]() ![]() |
Hi There, I have 2 things I want to do inside my range.
ps: not sure this topic doesn't go into the In Car Electronics section. 2008 TDV8 VOGUE - Buckingham Blue on Sand |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7976 ![]() ![]() ![]() |
For the second one - inside the car - I would get a Piggy Back fuse and run a cable from a switched live connection in the fusebox behind the glovebox.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35528 ![]() ![]() |
moved. |
I wouldn't try connecting your tracker to the outside air temperature sensor wiring, this is fed from the ac ECU and you may well upset the ECU.
thanks for the swift answers
no its an ignition feed and is live when the engine is running..
good. reading through right now. 2008 TDV8 VOGUE - Buckingham Blue on Sand |
Powerful posted some useful videos here that may help with taking pieces out of the dash & running cables. |
@cam-tech-craig yes, but the courtesy mirror is a high point to hook from
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8413 ![]() ![]() ![]() |
Why do you want a tracker to have a switched live, doesn't it need to be live all the time, mines got a battery backup but I'd still want it live all the time in case it's a while before you notice the car has been nicked...and personally I'd put it inside the car where it will have a kinder life and not be exposed to the elements....
@haylands after contact not to drain the battery but if the drain is minimal, then I'd be happy to put it on an always live wire.
after inspecting the characteristics, I guess you're right in saying it should be in a dry place.
Inside the car should be no worse than in the engine bay - it's still surrounded by metal for a GPS signal....
