Home > In Car Electronics (L322) > after contact 12v & inside 12v
Ibartsimp
France 2008 Range Rover Vogue TDV8 Buckingham Blue
Hi There, I have 2 things I want to do inside my range.
Live after + circa front grille
I'm going to stick a gps tracker there and would need it to be alimented when the car is on. Can I use the temp sensor cables? If not, what's the next best option. I would maybe consider a constant 12V but I have to figure out what would be the battery drain.
12V plug next to the instruments
On thing I regret from my previous TD6s is that the cigar lighter has moved further in the center dash, forcing me to run a cable right in the middle of the gear sticks and instruments.
Ideally, I would stick au USB plug of this kind but I'm open to other's experiences.
http://www.ebay.fr/itm/Allume-Cigare-Prise...4d1f28a83c
Thanks! 2008 TDV8 VOGUE - Buckingham Blue on Sand
Post #342404 14th Aug 2015 9:38am
Ibartsimp
ps: not sure this topic doesn't go into the In Car Electronics section. 2008 TDV8 VOGUE - Buckingham Blue on Sand
Post #342405 14th Aug 2015 9:42am
For the second one - inside the car - I would get a Piggy Back fuse and run a cable from a switched live connection in the fusebox behind the glovebox.
I would not put any new holes in the car - I would use the item you have linked to, but hide it & just run the USB cable to where you need it.
Post #342413 14th Aug 2015 9:50am
moved. Thumbs Up
i use an ignition feed for my drl switch and thats from the wiring to the headlight plug, cant see why you cant run a gps tracker from that.. ... - .- -.
Post #342416 14th Aug 2015 9:55am
I wouldn't try connecting your tracker to the outside air temperature sensor wiring, this is fed from the ac ECU and you may well upset the ECU.
You can connect to the headlight wiring as stan indicates above or into the E box as per my fifth post on page 5 of the link below.
Although this specifically applies to earlier cars I suspect the set up may be the same or very similar to later cars.
http://www.fullfatrr.com/forum/topic33047-60.html
Post #342422 14th Aug 2015 10:03am
Ibartsimp
thanks for the swift answers
@alistair got you but next question is how complex it is to run the cable to say the first cup holder.
@stan, @nicedayforit yes but then only has power when lights are on?
btw, what accessory do you use to stick your phone (iPhone 6 in my case)? 2008 TDV8 VOGUE - Buckingham Blue on Sand
Post #342424 14th Aug 2015 10:04am
no its an ignition feed and is live when the engine is running..
btw , its the green/blue wire running to the headlight plug.. ... - .- -.
Post #342425 14th Aug 2015 10:07am
Ibartsimp
good. reading through right now. 2008 TDV8 VOGUE - Buckingham Blue on Sand
Post #342427 14th Aug 2015 10:07am
Am i reading this right? You want a live whilst the vehicle is running? IE an ignition live? If so, the vanity mirror lights (illuminated sun visor mirror lights) are an ignition supplied 12v obviously at the top of the windscreen Thumbs Up
Post #342431 14th Aug 2015 10:12am
Powerful posted some useful videos here that may help with taking pieces out of the dash & running cables.
Post #342432 14th Aug 2015 10:15am
Ibartsimp
@cam-tech-craig yes, but the courtesy mirror is a high point to hook from
@alistair, the videos seem a bit old reg. console change. What I'd like is to "play" with the center console where the speed gear is located (possibly fitting a plug in the place of a cup holder).
For the GPS tracker I guess that things have changed on the TDV8 or I'm not looking at the right place
This is inside the front left box. 2008 TDV8 VOGUE - Buckingham Blue on Sand
Post #342443 14th Aug 2015 10:39am
Why do you want a tracker to have a switched live, doesn't it need to be live all the time, mines got a battery backup but I'd still want it live all the time in case it's a while before you notice the car has been nicked...and personally I'd put it inside the car where it will have a kinder life and not be exposed to the elements....
There is a great place I found for mine, PM me and I'll tell you where it is.... Pete
Post #342444 14th Aug 2015 10:47am
Ibartsimp
@haylands after contact not to drain the battery but if the drain is minimal, then I'd be happy to put it on an always live wire.
As to putting it inside the car, I'm afraid that it doesn't get a proper gps signal, no?
Sanding you a pm anyway for that secret place Wink 2008 TDV8 VOGUE - Buckingham Blue on Sand
Post #342456 14th Aug 2015 11:27am
Ibartsimp
after inspecting the characteristics, I guess you're right in saying it should be in a dry place.
Remains the question of how much drain a cigar lighter + USB cable will put on the battery.
Can it remain parked 2 weeks & still have no issue to start? 2008 TDV8 VOGUE - Buckingham Blue on Sand
Post #342460 14th Aug 2015 11:47am
Inside the car should be no worse than in the engine bay - it's still surrounded by metal for a GPS signal....
The lighter & cable use no power - unless there is some illumination on it - it's whats plugged into the other end that matters Whistle
Post #342465 14th Aug 2015 11:56am
