Home > In Car Electronics (L322) > Dash clock repair
sauzee
Dash clock repair
Hi guys i attempted to replace the lcd pixel ribbon on my daughters L322 Td6 today and when pulling the rev counter needle up it pulled the spring and snapped
Is there any way to get a replacement rev counter unit or will i have to buy a second hand binnacle if so do i need to have it reprogrammed
any help appreciated or someone selling a binnacle would be nice
Thanks
Sauzee
Post #340041 31st Jul 2015 1:18am
Think it's one piece, try one of the pixel repair services offered on ebay, they maybe able to fix it for you..
A second hand one will work but may show the wrong mileage and a marker to indicate that, they can be reprogrammed but I would think it would be cheaper to get yours repaired if possible...
Thumbs Up Pete
Post #340254 1st Aug 2015 11:38am
sauzee
Thanks for your reply i do know that the RPM and Speedo are just four solder points and they come out but if i can't get it repaired and need a replacement do i need the same number YAC002360PVA or can i use another unit or if the numbers don't match will it then require to be programmed
Thanks for any help
Sauzee
Post #340260 1st Aug 2015 12:30pm
Don't think anyone on here will know that sort of info, I have read somewhere that if you remove the needles you need some special equipment to recalibrate them... could be rubbish though...!! Pete
Post #340267 1st Aug 2015 1:14pm
sauzee
Hi i have managed to get a new pixel repair kit with the lcd and 2 new step motors for the speedo and rev counter from a company called AK speedo in Stirling £97 delivered thanks for your info
Sauzee
Post #340587 3rd Aug 2015 2:56pm
