![]() | Home > In Car Electronics (L322) > Dash clock repair |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8568 ![]() ![]() ![]() |
Think it's one piece, try one of the pixel repair services offered on ebay, they maybe able to fix it for you..
sauzee Member Since: 11 Jun 2015 Location: Edinburgh Posts: 8 ![]() ![]() |
Thanks for your reply i do know that the RPM and Speedo are just four solder points and they come out but if i can't get it repaired and need a replacement do i need the same number YAC002360PVA or can i use another unit or if the numbers don't match will it then require to be programmed
Don't think anyone on here will know that sort of info, I have read somewhere that if you remove the needles you need some special equipment to recalibrate them... could be rubbish though...!! Pete
Hi i have managed to get a new pixel repair kit with the lcd and 2 new step motors for the speedo and rev counter from a company called AK speedo in Stirling £97 delivered thanks for your info
