![]() | Home > Maintenance & Mods (L322) > *** FRONT BRAKE HOSE RECALL *** |
m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 333 ![]() ![]() ![]() |
I’m one of the last to get it done , it seems
kgeddes Member Since: 11 Jan 2015 Location: UK Posts: 289 ![]() ![]() ![]() |
I had the recall done very recently....I was warned that I might have to pay up to £500 if the brake pipes were corroded! |
There was no mention of additional costs if the steel pipes were corroded when I booked it in , but I had read that somewhere . So to be safe I cleaned up the joint where the flexi meets the steel pipe and gave it a dose of penetrating oil
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 ![]() ![]() ![]() |
Mine falls in the VIN number range.
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 705 ![]() ![]() ![]() |
We only got the Recall notice a few weeks ago & the earliest the local Dealer would fit in was in 2 weeks time.
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
When mine was done, a couple of years ago, they goosed one of the callipers which was replaced FoC. (Guy Salmon Knutsford) Previous cars:
G , If you call a dealer they’ll tell you
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1401 ![]() ![]() ![]() |
...and recall work should be noted in the service book. Only Range Rovers since 1988 |
Thanks, both.
Provarmint Member Since: 16 Aug 2017 Location: Warrington Posts: 76 ![]() ![]() ![]() |
Similar thing for me, bleed nipple seized on one of the calipers, waiting for the replacement caliper, then return to have the recall done. |
Need a couple of other things done, so booked in to mainstealer
SinbadRose Member Since: 21 Aug 2017 Location: Merseyside Posts: 114 ![]() ![]() ![]() |
Just checked mine on DVLA (thanks for that) looks like mine is still outstanding, so will give the not so local mob a ring to have it checked before booking in. |
Now booked in, no mention of any other costs/things that may need doing etc. Just have to wait until next month now |
When I booked mine in there was no mention of additional costs, it was when I took the FF to the dealer I was warned about the possibility of additional charges (up to £500 |
