Home > LPG > Can lpg be fitted to 5.0 SC MY2010 onwards?
Stuart
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Hi All
I currently run a MY54 V8 4.4 on lpg (BMW engine) and it is great!
I am thinking of buying a newer model and like the look of the MY2010 SC with 5.0 litre engine. Does anyone know if this can be converted to lpg? Has anyone on the forum done this?
I understand that there may be a new Prinz system that can be fitted to this model. Is this correct?
Thanks in advance!
Post #337922 19th Jul 2015 10:27am
I dont recall anyone running a 5.0 on LPG here Stuart... A few with 4.2’s but not 5.0’s from memory sir Whistle
Post #337959 19th Jul 2015 12:44pm
3528cc
United Kingdom 2008 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
5.0's are direct petrol injection, issue is that the petrol injectors use the petrol when injected to cool the injectors, otherwise they malfunction, being in the combustion camber i.e. heat.
It can be done but the injectors need to always have some petrol flow, sort f defeats the object......
Some systems exist for some direct petrol injection engines, but are expensive.
4.2's are indirect injection. Regards
Royston
2008 4.2 Supercharged Autobiography
1994 Classic Vogue SE
1999 Rover BRM
1987 Rover Vitesse Twin Plenum
Post #337964 19th Jul 2015 1:15pm
Stuart
That's what I suspected, guys. Many thanks for the replies. Thumbs Up
Post #337968 19th Jul 2015 1:34pm
Thumbs Up Thumbs Up Thumbs Up
Post #337976 19th Jul 2015 2:35pm
mzplcg
I've seen one and it had the Vogels (Polish I think) system on it. Uses 20% petrol and 80% LPG, as said above the petrol flow cools the injector tips which are in the cylinders, not the manifold. A very clever system from what I could tell, it even has the ability to run 7 cylinders on LPG and one on petrol if an LPG injector were to fail. Certainly a long way advanced from the days of vapour induction.
Seemed to run OK although I didn't drive it. Was a high miler too, 120K from memory.
Post #338108 20th Jul 2015 9:18am
