![]() | Home > In Car Electronics (L322) > LCD instrument cluster repair |
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
Has anyone just cleaned and reseated the ribbon cable with any luck? |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 ![]() ![]() |
The problem is the glue on the ribbon starts to melt over time and then the ribbon starts to perish and breakdown, so you may not be able to remove it cleanly. There are a few companies in the UK which will repair the cluster and there is a kit available on eBay for you to replace the ribbon yourself - not for the faint hearted as you have to drill through the back of the instrument cluster.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8514 ![]() ![]() ![]() |
Good question, also has anyone ever replaced it themselves successfully....??? Pete
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1901 ![]() ![]() ![]() |
I jumped ship on that one and got akspeedo to do the job.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35611 ![]() ![]() |
i tried doing my sons x5 and what a fiddly |
I have been in contact with Akspeedo. I'd like to see their instructions before I purchase parts or decide to send it off somewhere. For some odd reason that section of their site is password protected. I've seen PDF instructions for E39 repair. |
Is this cluster identical to any BMW models? I might get a bad one at a junk yard to practice on. I know its not quite the same but I'd have an idea if I want to trynit on the FF. |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
i second the post about leaving it to pro guy. i tried and cocked up the fuel guage, and it wasnt quite good either. for £20 you get the ribbon and instructions etc. and then you cock it up and buy another binnacle, (£100) and that one is no better. (and will have the dot) better still send it to akspeedo, and take a £90 hit and its all done. its still cheaper than a new tyre, which the 'road lotto' will throw at you anytime. |
joeypineapplez Member Since: 27 May 2015 Location: Waterford Posts: 68 ![]() ![]() ![]() |
I did this just yesterday and as stated already its not for the faint hearted. Im used to doing stuff like this on my old VWs but I wouldnt recommend it to a novice. The instructions make it look straight forward but its super fiddley and one slip of the drill could |
When I had a look there seemed to be two ways to do it, take the whole thing apart which means you need something to assist with reinstalling the needles correctly or drilling through the front so you can get to the screws without taking it all apart...
CY Member Since: 27 Mar 2007 Location: Scotland Posts: 146 ![]() ![]() |
I got mine back from cartronix today, I posted it to them on Wednesday lunchtime and it was back in my car this (Friday) evening |
jakebullet64 Member Since: 28 May 2014 Location: Wolverhampton Posts: 259 ![]() ![]() ![]() |
Hi Chaps,
Akspeedo hasn't responded to my question to see their instructions before committing to buy. Anybody have a copy? |
Mistercorn Member Since: 01 Feb 2014 Location: Nottingham Posts: 109 ![]() ![]() ![]() |
I did mine myself, it is a bit fiddly but if you take your time it is OK. There is nothing that is glued in which can't be re-done, so if it doesn't work 100% first time just take it apart again and retry. The instructions I had were clear and easy to follow, but I'm afraid I don't know if I still have a copy of them. The whole fix took me a couple of hours or so and total cost was under £20, well worth doing.
