Home > Technical (L322) > Braking over 50mph- steering shudder. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8536 |
I take it you have had wheels balanced?
5th Jul 2015 9:19am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
The rears when seized heat up the rear wheel on the offending side too, so can easily be checked by one wheel being hot |
5th Jul 2015 11:09am |
Phi. Member Since: 11 May 2015 Location: Halifax Posts: 14 |
Thanks chaps for the prompt reply- the rears seem fine with no noticeable difference in the temperature. |
5th Jul 2015 11:15am |
In that case change front wheels to rear and try again? Worst case, can you get/borrow another set of wheels to try?
5th Jul 2015 11:27am |
The discs are Eicher and the pads Pagid! On inspection they seemed to be ok with no uneven wear or scoring. |
5th Jul 2015 11:40am |
I had the front disc checked with a dial gauge, this showed that the discs were out of true.I have had them replaced and now the brake shudder has been sorted.
17th Jul 2015 5:29pm |
