![]() | Home > Maintenance & Mods (L322) > Leaf Blower? |
DannyH Member Since: 30 Apr 2015 Location: Hull Posts: 221 ![]() ![]() ![]() |
microfiber towel for me, if you're using the leaf blower/vac just make sure the bags empty before setting it to blow haha. Dan
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Don’t drive it in the rain & it won’t get dirty! |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
Tried this with my compressor. Flowrate wasn't enough to blow the water away with any degree of force and the tank wasn't large enough for anything more than a couple of minutes' use. By comparison, the dedicated air blower I now use will dry the car really quickly, especially when the air warms up. Si. <This is my name. I eat rat poison. A man ain't truly been insulted until he stands buck naked in front of a woman and she didn't even notice. Or care. |
I roll mine into the sun for 5 minutes |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1754 ![]() ![]() ![]() |
I also use a combination of micro fibre towels and an airline from the compressor. The towels do most of the hard work and I use the airline to blow out nooks and crannies. (like wing mirrors, door handles, bonnet scuttle)
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
You need a big compressor if you want to dry the car with air.
blackstoun Member Since: 22 May 2015 Location: Scotland Posts: 116 ![]() ![]() ![]() |
I used a SIDE KICK blower for years (but for all my bikes, bit puny for a big car) however I don't recommend them as they are a bit fragile, I went through two or three as they kept failing. ALSO they re 110 volts and come with a transformer built into the plug and it get a bit hot with longer use.
