Home > Maintenance & Mods (L322) > Leaf Blower?
Zirconblue
air line from a compressor also works well, you can use the air duster to dry out the engine bay after washing that too
Post #337356 14th Jul 2015 2:03pm
DannyH
England 2002 Range Rover HSE 4.4 V8 Zambezi Silver
microfiber towel for me, if you're using the leaf blower/vac just make sure the bags empty before setting it to blow haha. Dan
2002 Zambezi Silver
Men And Motors RR Quote - It's like having wheels fitted to your living room!
Post #337463 15th Jul 2015 1:39pm
Don’t drive it in the rain & it won’t get dirty! Whistle Very Happy Very Happy Very Happy
Post #337465 15th Jul 2015 1:47pm
Tried this with my compressor. Flowrate wasn't enough to blow the water away with any degree of force and the tank wasn't large enough for anything more than a couple of minutes' use.
By comparison, the dedicated air blower I now use will dry the car really quickly, especially when the air warms up. Si. <This is my name.
Post #337543 16th Jul 2015 4:17am
I roll mine into the sun for 5 minutes Thumbs Up 2008 MY Supercharged
Post #337545 16th Jul 2015 5:55am
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
I also use a combination of micro fibre towels and an airline from the compressor. The towels do most of the hard work and I use the airline to blow out nooks and crannies. (like wing mirrors, door handles, bonnet scuttle)
I find it pushes the hard to reach water out onto the body work then a quick mop up with the towel and it's done.
The most irritating thing is washing the car then going out.... all the drips from the wing mirrors end up spraying down the doors and the scuttle runs down the bonnet..! Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #337677 17th Jul 2015 9:10am
You need a big compressor if you want to dry the car with air.
I use a 23cfm Hydrovane and an air paint dryer to blow the water out of the crevices
Powered up without anything attached
This is it running with the air dryer attached,
Slight drop in pressure as the air dryer uses around 16cfm
Post #337712 17th Jul 2015 12:29pm
blackstoun
Scotland 2006 Range Rover Supercharged 4.2 SC V8 Java Black
I used a SIDE KICK blower for years (but for all my bikes, bit puny for a big car) however I don't recommend them as they are a bit fragile, I went through two or three as they kept failing. ALSO they re 110 volts and come with a transformer built into the plug and it get a bit hot with longer use.
I now use one of the these
http://www.ebay.co.uk/itm/LEAF-BLOWER-ELEC...3cf3a8c57e
Cheap, but seems to work well for both bikes and FF (and Motorhome) , if you modify the nozzle to get a flatter air stream, I used one of the wider nozzle ends from the old busted SideKicks, and some gaffer tape!!
Post #337714 17th Jul 2015 12:41pm
