Home > General > why?
why?
why do the temperature knobs only go down to 16 degrees, what if i want a 10 degree temperature in the cab.. ... - .- -.
Post #336960 12th Jul 2015 7:18am
mjdronfield
In the manuals or workshop docs it states it's not an actual temperature that's achieved, just a target. Or similar words. When I had my air con serviced a couple of weeks ago the temp inside was measured at 8 degrees, which is not on the dial either. All the way cold will blow cold all the time....
I'm sure there is a better explanation somewhere..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #336962 12th Jul 2015 7:35am
Ac systems in vehicles including cars are designed to provide a minimum cab temperature of 16C to prevent the occupants suffering "thermal shock", which can be fatal, when exiting the cab into potentially far higher temperatures.
This came about after a number of fatalities in the US where farmers would plough fields all day in air-conditioned tractor cabs set to relatively low temperatures only to more or less drop dead when getting out of the cabs at the end of the day into temperatures exceeding 40C.
16C is now used universally as a design minimum although with a bit of fiddling you could probably make it go lower if you wished to.
Much lower of course and you will need a pullover. Very Happy
Post #336964 12th Jul 2015 8:10am
I have to ask why you'd ever want 10'C, Stan?
I shiver at anything less than 20'C. Laughing Si. <This is my name.
Post #336965 12th Jul 2015 8:14am
all down to tractor drivers then Twisted Evil
the reason i ask is that when [in winter] in get into the FF with me coat on i find 16 much to warm and most times its inconvenient to take off the coat..i have no idea why this query has cropped now in the middle of summer, its the way my head works Confused ... - .- -.
Post #336966 12th Jul 2015 8:16am
Yeah, I find removing a coat such a faff. Unzip, one arm off, then the other... BORING!!!!!!!!!!!!!!! Ten seconds of my life I won't ever get back. Laughing
Don't you employ a butler for such tasks? Laughing Si. <This is my name.
Post #336967 12th Jul 2015 8:24am
just wondering if its worth a trip to berkshire to slap you with a wet kipper... Twisted Evil
Wink ... - .- -.
Post #336968 12th Jul 2015 8:31am
Laughing Laughing Laughing Si. <This is my name.
Post #336973 12th Jul 2015 9:04am
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
And then theirs the rain, maybe Stan doesn't like getting wet either.......but then I guess the butler would get wet also Laughing If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #336975 12th Jul 2015 9:11am
you're the list as well mike Twisted Evil ... - .- -.
Post #336976 12th Jul 2015 9:12am
Welshdragon
You'll have to catch me first....now give us a minute to tack up the horse... Rolling with laughter Rolling with laughter If it dont work.......burn it!
Post #336977 12th Jul 2015 9:16am
Hmmmmmmmm Kippers... Breakfast hmmmmmmm
Ta for the idea Stan Thumbs Up
Post #336983 12th Jul 2015 10:13am
Zirconblue
Just switch the climate control off and open the windows/sunroof.
I suspect the biggest reason they only bottom out at 16deg is the cabins aren't really insulated (like a fridge) so the amount of cooling power required to pull the temperature down and maintain it in summer would be impractical, plus you'd be getting frost bite with the wind chill effect.
Post #336990 12th Jul 2015 11:19am
If we wanted 10 degrees in Scotland we have to put the heater on Stan. So think yourself lucky! Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #336993 12th Jul 2015 11:35am
always cold up there isnt it alan......
@craig, wet kipper slap and then breakfast ? Laughing ... - .- -.
Post #336996 12th Jul 2015 11:54am
