![]() | Home > Technical (L322) > EAS stuck in Motorway mode |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
Have you got any warnings in the driver's info screen or an "i" icon come up? Often the first line of a fix is to switch off the ignition and leave the car for 5 minutes with no power, then switch back on again - often the reboot of all the systems clears the fault but logs it in the ECU fault codes log. If you are on the north side of Glasgow and continue to have EAS problems I know a non franchise specialist out at Larbert who is very familiar with the problems of Land Rover EAS systems from the Disco2 system right through P38A (his speciality) to today's systems 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Hi Tim, Thanks for your quick reply.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35647 ![]() ![]() |
your FFRR should still be in motorway mode..i did this the other day and i'm pretty sure mine stayed like that until we came off the motorway and travelled about 5 miles at 40 mph and then it went up to standard. ... - .- -.
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 ![]() ![]() ![]() |
From the handbook:-
Just back from a run up the motorway and once again I had to manually change it onto standard height after over 5 minutes of driving at 25-30mph.
Here you are, George Maclay is the proprietor and 2nd in command is Bobby.
Thanks Tim |
Just added some more info to the post 47. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
Thanks Tim, I've given him a call but he isn't in at the moment, the lass in the office will have him call me back later today |
Ah that was Wendy, the new recruit! The other person who could help you would be Bobby, the No2 at GEMM. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
andyw Member Since: 15 Oct 2009 Location: united kingdom Posts: 160 ![]() ![]() ![]() |
john,
Andy, thanks for your reply.
dont think its an up grade recall
I was out in the RR today and when I left the motorway the EAS eventually did go back to standard, but that was after I stopped at traffic lights for about 40 seconds and then drove another five minutes. As Alex has said it could be a simple software update that is required.
