Home > Technical (L322) > EAS stuck in Motorway mode
I took the RR to GEMM today and had it plugged into the computer. No faults showed up for the suspension, so a test run was done and Bobby seems to think it is working ok, possibly a fraction slow on changing from motorway mode back to standard mode. I guess I will have to let it develop Sad
The bad news however is that the engine management light wasn't coming on when the ignition was turned on, the computer is showing an EGR fault, Bobby cleared the fault and after the test drive checked again, the fault is back.
When I returned home I removed the dash from the vehicle and have stripped the cluster. I'm no electronisc expert but my guess is the management LED looks like it has been on for a while and fried some of the circuit board.
This is the LED in question
None of the other LEDs have the melted gloop round them
The good news is I met up with Tim whilst at GEMM and we went for a coffee at the Falkirk Wheel. Thanks for your assistance Tim, good to meet you Thumbs Up
Post #31544 12th Oct 2010 4:39pm
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
Nice to meet you John and have a chat, just hope this hasn't opened a new can of worms for you! Might be worth considering the EGR blanking route (there are kits available and GEMM would be able to obtain one and fit it) but I don't know if this will leave the engine management light on all the time too - maybe one of the more techie people here will know. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #31547 12th Oct 2010 5:09pm
If it has to be repaired Tim I'll just have to bite the bullet and have it done.
If blanking off the EGR valve is an option without upsetting the engine management system I would be interested in looking into that
Post #31548 12th Oct 2010 5:25pm
Tim in Scotland
It has been done by a few on here John, if you use the search facility you should turn up a few posts 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #31554 12th Oct 2010 6:09pm
Captain Slog
United Kingdom 2005 Range Rover Vogue Td6 Java Black
Hi
I'm travelling back to the UK from Greece at the moment and while travelling through Switzerland on the motorway I heard a 'ping' looked at the dash and saw the dreaded 'Air Suspension Inactive' message.
The car feels OK and I don't have any other messages or warning lights but the suspension is locked at normal ride height.
I pulled up at the earliest opportunity but after turning off the engine and waiting for 30 minutes then re-starting the fault remains.
Will it hurt to run the car at normal ride height at motorway speeds until I get back to the UK?
Does anyone know how to clear the message and return the car to normal operation without a trip to a main stealer?
_________________
Currrent: 2005 FF Range Rover L322 Vogue TD6
Gone: 1999 Range Rover P38 HSE TD6
Gone: 1985 Land Rover 90 SWB diesel
Post #31578 13th Oct 2010 5:51am
Tim in Scotland
It won't damage the car, the reason it lowers at motorway speeds is to help stablity and aerodynamics 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #31581 13th Oct 2010 6:19am
I thought I could strip the cluster and check the LED with a meter, but unfortunately there is a chip on the underside of the LED which never allowed access so I have put everything back together for now.
The light isn't on so it won't bother me too much Big Cry
Post #31604 13th Oct 2010 1:03pm
Tim in Scotland
John, remember what Bobby said - Black paper or tape over the light will put it out too Whistle Rolling with laughter 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #31627 13th Oct 2010 4:56pm
I don't need it out Tim, it doesn't bloomin light up Big Cry
Post #31655 13th Oct 2010 8:29pm
