![]() | Home > Technical (L322) > New Owner Some Questions.. |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
Parking Sensor - possibly one is damaged or could be dirty/full of water if the car has been pressure washed too vigorously.
red_slr Member Since: 06 Oct 2010 Location: Manchester Posts: 42 ![]() ![]() ![]() |
I have put my ear to each of the sensors... its clicking away so I guess it might be the water issue.
It's a bumper off job |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35652 ![]() ![]() |
like TIM says ..if the dealer pressure washed it before you picked it up then thats your cause..i would hold tight for a week or two and see if the water evaporates ... ... - .- -.
Sneak the wife's hairdryer out to the garage, that speeds up the drying process. Amazingly useful auto-tools are hairdryers, far more useful than their original use suggests |
I use them to remove off road event sponsorship stickers from my RR |
darrenmax Member Since: 20 Apr 2010 Location: antwerp Posts: 420 ![]() ![]() ![]() |
i changed both front calipers last month, really easy, clamp flexible hose, remove caliper remove hose, then fit new one in reverse order, i bled the calipers using an eazibleed kit, dont know if thats a brand that you have in the uk or not but it was quite cheap and did the job great, about half an hour each side with new discs and pads 2002 td6 vogue, 06 supercharged facelift
Thanks chaps. Looks easy to replace then so that should be ok.
delamo Member Since: 17 Mar 2010 Location: Beaconsfield, Bucks Posts: 1121 ![]() ![]() ![]() |
I would try and find a used one from a warranted breakers yard, or just buy the part new from LR - can't be that hard to replace the broken one.
Caliper change done. Seems ok now |
Never try to replace the mirror glass yourself on any of the more recent LR cars - the glass always cracks/breaks - leave it to a dealership as they have a special tool for the job (and if they break the mirror it costs the dealer not you!)
Yep lesson learnt now!
http://www.1stchoice.co.uk/Cars/Rover/?gcl...4wodwDFmUA
Ordered a new one from my dealer... £518... ouch! |
