![]() | Home > Technical (L322) > New Owner Some Questions.. |
red_slr Member Since: 06 Oct 2010 Location: Manchester Posts: 42 ![]() ![]() ![]() |
Thanks had a look around last night, looks like it might be difficult to find a folding chromatic one off an x5 so I am going to stick with LR as its due in tomorrow. Thanks anyway |
darrenmax Member Since: 20 Apr 2010 Location: antwerp Posts: 420 ![]() ![]() ![]() |
the x5 mirror is different where it fits to the car, the rest of the parts are the same, just a different mounting triangle so it wont fit but you can strip one for the housing, motors and mirrorglass 2002 td6 vogue, 06 supercharged facelift
Small update - mirror arrived from LR on Monday. Installed on Tuesday. Fairly easy to install, only held on with 3 bolts, 2 connections and that was it. Worked with no reprog of the ECU etc.
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
Welcome to Range Rover ownership, you will be perceived as being of above average means from now in! 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
Seems to be the case!
