![]() | Home > Maintenance & Mods (L322) > Umbrella holder |
DavidB64 Member Since: 03 Aug 2017 Location: Wrea Green Posts: 38 ![]() ![]() ![]() |
Strider, bought the same, as they look fab on your post - didn't note that it was rivets and not screws that hold the plates onto the underside of the luggage cover and just holding off as I didn't really want two silver rivet heads showing on the top surface of the cover - has anyone screwed these into the cover rather than rivets or stuck them on? Thanks |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1550 ![]() ![]() |
What is this umbrella of which you speak? Ron B. VK2OTC
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35545 ![]() ![]() |
they call it a sun shade down where you are... |
Where I come from sunshine only comes in its liquid form ! |
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 751 ![]() ![]() ![]() |
That's how mine was fitted originally! But the rivets gave up the ghost and the holders fell into the boot! So I went to my local man and he sliced holes in the side of the double skin and managed to place washers inside, then re riveted it! Solid as you like now!! 2014 vogue se |
Thanks for the advice |
rodp Member Since: 09 Apr 2017 Location: The Black Country Posts: 318 ![]() ![]() ![]() |
Wondered about rivets or screws pulling through. So, it looks like a Dremel job then, did you put a slot on the back of the corrugation and just slide a penny washer in? |
