Home > Maintenance & Mods (L322) > Umbrella holder
Cool I removed the panel with the recess - the additional battery is behind there so it just pulls off.
I had a few of the black washer type things from an old awning - so I drilled some holes and then nut & bolt with a penny washer on the back.
Was a bit fiddly doing the ones by the switch panel as I just pulled it pout enough to get my hand behind Thumbs Up
I might still gave a few of the black washer things (I have no idea what they are called) in France - I'm there next week so will take a look in my shed.
Post #439224 22nd May 2017 8:21am
DavidB64
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Barolo Black
Strider, bought the same, as they look fab on your post - didn't note that it was rivets and not screws that hold the plates onto the underside of the luggage cover and just holding off as I didn't really want two silver rivet heads showing on the top surface of the cover - has anyone screwed these into the cover rather than rivets or stuck them on? Thanks
Post #448098 17th Aug 2017 9:54am
p38arover
Australia
What is this umbrella of which you speak? Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #448099 17th Aug 2017 10:01am
they call it a sun shade down where you are... Laughing ... - .- -.
Post #448105 17th Aug 2017 11:10am
DavidB64
Where I come from sunshine only comes in its liquid form !
Post #448106 17th Aug 2017 11:12am
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
That's how mine was fitted originally! But the rivets gave up the ghost and the holders fell into the boot! So I went to my local man and he sliced holes in the side of the double skin and managed to place washers inside, then re riveted it! Solid as you like now!! 2014 vogue se
Post #448130 17th Aug 2017 2:20pm
DavidB64
Thanks for the advice
Post #448132 17th Aug 2017 2:24pm
rodp
United Kingdom 2003 Range Rover Vogue Td6 Bonatti Grey
Wondered about rivets or screws pulling through. So, it looks like a Dremel job then, did you put a slot on the back of the corrugation and just slide a penny washer in?
Post #448147 17th Aug 2017 3:56pm
