Home > Technical (L322) > Limp mode? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35271 |
are sure neighbour put diesel in and not petrol? ... - .- -.
28th Jul 2015 11:16am |
Boydonegood Member Since: 12 May 2014 Location: Essex Posts: 445 |
Na was definately diesel. Wouldn't it just cough and splitter with crap diesel tho? It seems like something is limiting it to 2750-3000 revs
28th Jul 2015 11:20am |
Definately seems like it's being limited electronically.
28th Jul 2015 11:31am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
Fuel filter. |
28th Jul 2015 11:39am |
Will definately drain the 1/4 tank out (somehow) and change filter. But would that cause the issue of some kind of limp mode? It's definately being limited electronically rather than fuel starvation. I.e would the fuel issue throw it into a limp mode? If so does it clear itself when running ok again as in left sitting Or does it have to go on PC to clear?
28th Jul 2015 11:50am |
Paul_H Member Since: 17 Dec 2013 Location: Bracknell Berks Posts: 126 |
External fuel pump/filter? I had similar with mine 2005 Range Rover Vogue with Supercharged Accessories
28th Jul 2015 12:37pm |
mike whiskey Member Since: 11 May 2015 Location: Huntingdon Posts: 114 |
The problem is all of this is guesswork until you can get it on a diagnostic. If the ECU is limiting it then this should say so, and why.
28th Jul 2015 12:42pm |
Blocked fuel filter would result in limited revs without logging a fault or showing a message on the display.
28th Jul 2015 12:48pm |
Yeah I suppose I'll have to invest in a Diagnostic machine. Until then I'll have to limp it to Beadles Main Dealer I suppose.
28th Jul 2015 12:53pm |
So Saturday and the suns shining so time to look at the FF. Threw a cheap fuel filter on (theory is to change it again in a week) and still getting exact same symptoms.
1st Aug 2015 4:31pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
Blimey, that's weird Tel.... guess it was dodgy fuel then.... Pete
1st Aug 2015 4:38pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
What makes you say it has antifreeze in the fuel? |
1st Aug 2015 5:01pm |
Definitely change the fuel filter again once you've had a few days running. |
1st Aug 2015 5:03pm |
Yeah seems it was fuel causing the issue. Was definately antifreeze as was bright blue droplets and I tasted it!
1st Aug 2015 6:05pm |
