Home > Maintenance & Mods (L322) > TDV 4.4 oil drain refitting? |
tomass311 Member Since: 11 Apr 2018 Location: presov Posts: 2 |
Hi, did you figure out this thing? I have same issue, i got the oil change and I think that before the chage it was deeper inside. Thanks for response |
15th Apr 2018 4:28pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
16th Apr 2018 2:57pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35419 |
thats very helpful nino.. ... - .- -.
16th Apr 2018 3:01pm |
Thanks a lot |
16th Apr 2018 4:01pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8659 |
16th Apr 2018 8:45pm |
ScubaVogueSE Member Since: 07 Apr 2019 Location: Kent Posts: 29 |
Hi. Im trying to drain the oil.
22nd Feb 2020 12:01pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
Very hard squeeze and wiggle and pull of the two recessed tabs all at the same time.
22nd Feb 2020 12:04pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4308 |
Or buy a vacuum pump and suck it out via the tube on top of engine. So much easier and cleaner.
22nd Feb 2020 12:29pm |
Thank you. Managed to get the bottom plug thingy off and back on again. Hope it doesn't leak.
22nd Feb 2020 1:58pm |
