Home > Maintenance & Mods (L322) > TDV 4.4 oil drain refitting?
The oil level was high on the display so i decided to drain some out from under the car.
I have been under it and drained out about 1/2 a litre, and it is now reading right.
One question, HELP, before i put the under tray on.
I can't push the fitting on any more than this, i don't think it was on any more to start with. There only seems to be one lip for it to latch over. Cant push it home any further even if I squeeze the clips. It won't pull off even with a bit of force but will pull back and forwards a bit....
help...... Bow down Bow down Bow down don't want to drive off tomorrow and it come off and dump all the oil on the road and have a big bang expensive engine replacement moment........ There is nothing that can't be fixed with a hammer๐Ÿ˜œ๐Ÿ˜œ
Post #333618 20th Jun 2015 5:52pm
tomass311
Slovakia 2012 Range Rover Vogue 4.4 V8 Java Black
Hi, did you figure out this thing? I have same issue, i got the oil change and I think that before the chage it was deeper inside. Thanks for response
Post #475923 15th Apr 2018 4:28pm
nino_nino
tomass hope this helps:
Post #476009 16th Apr 2018 2:57pm
thats very helpful nino.. Wink ... - .- -.
Post #476010 16th Apr 2018 3:01pm
tomass311
Thanks a lot Very Happy
Post #476021 16th Apr 2018 4:01pm
In the end the bleeding fitting was leaking and the dealer replaced it under warranty. So Iโ€™m a happy bunny. There is nothing that can't be fixed with a hammer๐Ÿ˜œ๐Ÿ˜œ
Post #476034 16th Apr 2018 8:45pm
ScubaVogueSE
United Kingdom 2011 Range Rover Vogue SE TDV8 Orkney Grey
Hi. Im trying to drain the oil.
How does this come out to drain?
And go back on? Struggling.
Thanks Steve
Sittingbourne, Kent, UK
2011 4.4 TDV8 Vogue SE
Post #544787 22nd Feb 2020 12:01pm
GGDR
Very hard squeeze and wiggle and pull of the two recessed tabs all at the same time.
For peace of mind, measure how much gap there is before removing so when you put it back you know it's seated.
Other get the Draper suction thingy.
I'm a dropper myself.
. Thumbs Up Cheers, Greg
Post #544789 22nd Feb 2020 12:04pm
DrRob
Or buy a vacuum pump and suck it out via the tube on top of engine. So much easier and cleaner.
Greg is a dropper, I'm a sucker Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #544794 22nd Feb 2020 12:29pm
ScubaVogueSE
Thank you. Managed to get the bottom plug thingy off and back on again. Hope it doesn't leak.
I may look into sucking in the future! ๐Ÿ˜Š Steve
Post #544805 22nd Feb 2020 1:58pm
