Home > Technical (L322) > Spare Key -Battery Problem
cgarside
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
None of the remote unlock functions on the spare key I have for my Range Rover work any longer.
I have been told that the key battery is recharged automatically when the key is in the ignition, so there is no conventional battery to change.i would welcome any advice on my options here - can the rechargeable battery be changed or will I need a new key ?
Thanks in anticipation
Chris
Post #331601 8th Jun 2015 9:49pm
Zirconblue
My understanding is they're recharged when in the ignition. So the logical thing to try is to use it for a week or so to charge it up. If you're the only person that drives it then you can just alternate between the keys once in a while.
Post #331615 8th Jun 2015 10:34pm
cgarside
Thanks for your reply Zirconblue.
I have used the spare key for a week but despite this, the remote function failed to work.
The RR is under warranty, but before I go back to the dealer I would like to know whether it is possible to change the battery or if the battery has failed, a complete new key is needed. I should also add that the spare key appears unused so given I have an 08 vehicle, what is the likelihood that the battery has failed.
Regards
Chris
Post #331704 9th Jun 2015 6:53pm
Zirconblue
One problem that used to happen with old Rover's is if the remote had a battery change or was pressed several times when out of range of the car. The solution was to press the unlock button about 5 times to get the rolling codes resynchronised. I wonder if it's the same on the RR?
Post #331707 9th Jun 2015 7:01pm
cgarside
Just been out try the unlock button five times - sadly no joy.
Will call the dealer to get their view.
Thanks, chris
Post #331715 9th Jun 2015 7:16pm
rangie47
had this on the spare key of mine when I bought it ,took it to the local indy and he re sync'd it to the vehicle for me free of charge ,need to go back know as I want global opening Rolling Eyes 2007 tdv8 se ,stornaway grey
Post #331722 9th Jun 2015 7:35pm
cgarside
Thanks, that's jogged my memory. I had to reprogramme a spare key fob on another car a year ago. I will make some calls tomorrow and see if I can get hold of the re-sync routine.
Chris
Post #331730 9th Jun 2015 8:00pm
rangie47
you cant do it yourself it needs to be plugged in Thumbs Up 2007 tdv8 se ,stornaway grey
Post #331751 9th Jun 2015 9:17pm
cgarside
Didn't get the resync procedure but did follow rangies47's advice and went to the dealer. All done under warranty and sure enough the key re- programmed ok. Both keys now work fine
Thanks for the comments.
Chris
Post #333211 18th Jun 2015 7:42pm
rangie47
Post #333274 19th Jun 2015 5:55am
