Home > Maintenance & Mods (L322) > Dash cup holder won't come out fix....
chex
Kenya
I think the first post in this thread explains exactly that?[/img] 2004 L322 V8
Post #584614 20th Feb 2021 6:38pm
Naki
United Kingdom 2003 Range Rover Vogue Td6 Java Black
It’s possible mine has a different fault then.
The pictures are missing, so it’s hard to visualise what he’s describing without that.
Mine has no siding action at all.
Without being familiar with what it should look like, I suspect something maybe be missing/ broken off. As I cannot see any kind of mechanism that would spring load it to come out. In the way I assume it should. 2007 L322 TDV8 3.6 Vogue SE
2006 L322 S/C 4.2
2003 L322 TD6 Vogue with Facelift conversion
2000 Discovery 2 TD5 ES. Daily
1990 RRC 3.9 V8 LPG
Too many Jaguars!
Post #584619 20th Feb 2021 7:13pm
Naki
2006 L322 S/C 4.2
1990 RRC 3.9 V8 LPG
Too many Jaguars!
Post #584620 20th Feb 2021 7:13pm
Naki
Do those are the pics of mine. I assume the little damper cog thing is missing? 2007 L322 TDV8 3.6 Vogue SE
2006 L322 S/C 4.2
1990 RRC 3.9 V8 LPG
Too many Jaguars!
Post #584621 20th Feb 2021 7:14pm
Yep, cog is gone and also the spring that ejects it from what I can see...
Get one off eBay or a new one is £100 if you can get one..!! Pete
Post #584625 20th Feb 2021 7:53pm
Naki
Ok, thanks for clarifying. I thought they must be something missing, otherwise I likely could have worked out a fix.
These seem to be comparing £47-£80 in the UK online now? I was optimistically hoping it may be repairable as others say they have done, but it’s not to be.
So I will probably leave it, with other priorities to attend to on the car.
Thanks for clarifying for me.
Is there a way to get the OP pictures back up? That will help others. 2007 L322 TDV8 3.6 Vogue SE
2006 L322 S/C 4.2
1990 RRC 3.9 V8 LPG
Too many Jaguars!
Post #584637 20th Feb 2021 8:40pm
Naki
Apparently still available new from LR in the UK. But a less Palatable cost for something that will get very little use on my car.
Land Rover Holder - Cup (FBD000022PUY) part for Range Rover 2002 - 2009. Authentic Land Rover Part.
£165.73 2007 L322 TDV8 3.6 Vogue SE
2006 L322 S/C 4.2
1990 RRC 3.9 V8 LPG
Too many Jaguars!
Post #584638 20th Feb 2021 8:44pm
Naki
The only other long shot is to cannibalise parts off another unit, to use on it. Maybe BMW?
We’ll see, it’s dropped down the list at the moment. 2007 L322 TDV8 3.6 Vogue SE
2006 L322 S/C 4.2
1990 RRC 3.9 V8 LPG
Too many Jaguars!
Post #584639 20th Feb 2021 8:46pm
Swipe
United Kingdom 2004 Range Rover Autobiography Td6 Java Black
Fixed mine the other day cup holder wouldn’t pop so replace the constant force spring, now as good as new
https://www.expresselectrical.co.uk/Catalo...-22-mm-P61 2004 Autobiography TD6 Java Black
Post #585118 24th Feb 2021 8:03pm
Naki
Good info.
I think mine has too many missing parts to try this unfortunately. 2007 L322 TDV8 3.6 Vogue SE
2006 L322 S/C 4.2
1990 RRC 3.9 V8 LPG
Too many Jaguars!
Post #585119 24th Feb 2021 8:07pm
