Home > Maintenance & Mods (L322) > Aerosol Paint Quantity
Richard
United Kingdom 2002 Range Rover Vogue 4.4 V8 Adriatic Blue
Could anyone give me an idea of how many ml of paint I would need if I wanted to paint some mirror covers and handle covers body colour?
Also is Halfords paint and primer ok? Or would it be better to get it from one if the many online services?
Thanks in advance Very Happy
Post #328237 17th May 2015 7:08am
Why not order them here?
http://www.powerfuluk.com/products/range-r...-blue.html
Send them an email and ask for a quote for the mirror covers too? You would arguably get a better finish then rattle cans sir Bow down
Post #328240 17th May 2015 7:37am
Mikey
With a bit of time, and patience, you can get a good finish with Halfords rattle cans.
Much quicker and easier to get get someone else to do it though Thumbs Up
Post #328242 17th May 2015 7:47am
On a £20k + motor car Mickey... Really Shocked Its not a rusty wheel arch on a £200 Escort!!!
And you wonder why we often disagree Rolling Eyes Rolling Eyes Rolling Eyes Embarassed Whistle
Post #328244 17th May 2015 7:54am
Rosco
Ah Craig, a £200 escort, old 3.0 litre engine and a can of spray paint, that's how to spend a Sunday back in the day !! Thumbs Up
Post #328248 17th May 2015 8:02am
True - but if you have to ask his question, make that a LOT of time & practice Whistle
Post #328249 17th May 2015 8:13am
One can per cover should do it, along with a can of lacquer for each, proper colours and packs available from Duckworths Dan. With metallic paint do not rub down before applying lacquer otherwise it flats off all the sparkly bits. Get a good key for your lacquer though otherwise it won't be long before it starts to lift/bubble (speaks from experience)
IMHO nothing wrong with the rattle can approach for the small removable items on the car :fins, grille, mirror covers, but practice makes perfect.
Post #328250 17th May 2015 8:56am
Mikey
An 02MY 4.4 V8. £20k+? I'll just start shipping them down to you Thumbs Up
And yes, put in a small amount of effort into the prep, and some careful spraying, and you would never tell it wasn't done by a bodyshop.
The whole purpose of forums is to save fellow members a bit of money...
Post #328251 17th May 2015 9:02am
Richard
Thanks for the advice and YouTube link. Thumbs Up
Post #328252 17th May 2015 9:11am
Zirconblue
Even if they stock your colour on the shelf in Halfords. You're better getting them to mix you a can. Reason being the cans they use for mixing come with a much better valve assembly on them. Whereas the off the shelf ones sort of spray a round cone of paint, the mix ones put out a flat fan spray, much the same way a spray gun does. It lays the paint down much better.
Their primer is ok, but you'll probably get it more cheaply on line or from a local bodyshop supplies firm.
Post #328287 17th May 2015 12:51pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
I use Paints4u as Halfords stuff is rubbish and always tends to react whenever I have used it.
https://www.paints4u.com/
I did the whole front bumper from rattle cans supplied by them when putting on my winch kit. Looking at it you would have thought it was professionally sprayed, the colour match was spot on even though it was metallic (hardest to get right). The key to a good finish is preparation, preparation and preparation!
Post #328336 17th May 2015 6:54pm
^+1 for Paints4U, used them many a time with really good results. Thumbs Up
Post #328338 17th May 2015 7:05pm
Zirconblue
Agreed, i'd also add a warm dry environment too. Damp is your enemy when it comes to diy spraying. Not really an issue for a pro in a paint booth.
Post #328351 17th May 2015 8:04pm
