Home > Maintenance & Mods (L322) > 2010 Touch screen cleaning |
Yeah i used baby wipes on mine when i had it took the finger prints off no problem ... also takes the top film off as well but doesn't do any lasting damage ====================================
16th May 2015 6:35pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
I bought a matte iPad screen saver, cut it to size, fitted it and 'voila' all sorted now... No more fingerprints |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
Alcohol wipes will do it.
16th May 2015 7:22pm |
Just to add to this thread, most 09> ff.’s i see have significant wear on the screens where fingers press the same place over and over again... JLR seam to have used a poor standard of touchscreen material as they wear very early on in their lives!!!
17th May 2015 7:49am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1387 |
Craig, thanks for the tip about the iPad screen saver. I cleaned my 2012 screen with the cloth that was supplied in the LR wallet that contains the handbook etc (I don't know if it is standard LR issue or was put in by the dealer) and found that there were residual wear marks on the screen exactly as you described. I take it that the screen saver just adheres to the screen without any adhesive or other fixing? Only Range Rovers since 1988 |
17th May 2015 2:19pm |
Yes, just like the ones you stick on mobile phone screens sir |
17th May 2015 2:21pm |
