Home > Maintenance & Mods (L322) > 2010 Touch screen cleaning
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Anyone tried with any success to clean the central touch screen? The handbook says clean with a lightly moistened cloth but this does very little to remove the pesky finger marks so obvious on a sunny day.
I know chemicals are generally a no-no but wonder if anyone has ben rebellious enough..
Cheers 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #328205 16th May 2015 7:27pm
Yeah i used baby wipes on mine when i had it took the finger prints off no problem ... also takes the top film off as well Laughing but doesn't do any lasting damage ====================================
Post #328207 16th May 2015 7:35pm
I bought a matte iPad screen saver, cut it to size, fitted it and 'voila' all sorted now... No more fingerprints Thumbs Up
Post #328208 16th May 2015 7:35pm
Zirconblue
Alcohol wipes will do it.
Camera lens cleaner should also be fine.
Even a dry micorfibre cloth should get rid of most of it.
Post #328213 16th May 2015 8:22pm
Just to add to this thread, most 09> ff.’s i see have significant wear on the screens where fingers press the same place over and over again... JLR seam to have used a poor standard of touchscreen material as they wear very early on in their lives!!! Rolling Eyes
Im sure some will mistakenly identify this as dirt Shocked
The method i suggested above also covers the wear too Thumbs Up
Post #328243 17th May 2015 8:49am
CS
Craig, thanks for the tip about the iPad screen saver. I cleaned my 2012 screen with the cloth that was supplied in the LR wallet that contains the handbook etc (I don't know if it is standard LR issue or was put in by the dealer) and found that there were residual wear marks on the screen exactly as you described. I take it that the screen saver just adheres to the screen without any adhesive or other fixing? Only Range Rovers since 1988
Post #328301 17th May 2015 3:19pm
Yes, just like the ones you stick on mobile phone screens sir
Post #328302 17th May 2015 3:21pm
