Home > Maintenance & Mods (L322) > Anybody able to tell if these are tow bar gubbins |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8516 |
I would say yes they are the remains of a tow bar. Definitely not the original bits which go there. Not a genuine LR bar though so identifying it may be a bit tricky. I would start with a browse of PF jones site and see if any of the brink or witter bars look similar. There is nothing that can't be fixed with a hammer😜😜
13th May 2015 7:06pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Agree with above... Certainly NOT OE kit sir |
13th May 2015 9:46pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
Look like the remains of an after market tow bar. Not the Westfalia one. |
13th May 2015 9:47pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Recon they are the left over from a Witter tow bar that was removed in a hurry Yesterday I couldn't spell Engineer... Today I are one!
13th May 2015 10:27pm |
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 |
Sorry to go off topic but..."gubbins" That's a great word - proper northern talk |
14th May 2015 6:54am |
Mustard Member Since: 25 Jun 2013 Location: North of South Posts: 299 |
Best to remove it all then and start from afresh instead of trying to play pin the tail on the donkey.
21st May 2015 10:38am |
Gubbins fits more terms than bobbins |
21st May 2015 10:40am |
I'd agree with that. The cost will be little different. What happened to the wiring? Has it been hacked off, or removed properly and did they replace the rubber bung where the wiring went through? |
21st May 2015 11:03am |
Not sure, theres no mess hanging around the area (in or out) so will have to look a bit deeper for the answer to that question.
21st May 2015 11:17am |
Probably left these bits on to save removing the bumper, and just unbolted all the easy bits.
24th May 2015 10:45am |
birchyman71 Member Since: 18 Feb 2013 Location: stockton on tees Posts: 147 |
Mine has the same brackets but the electrics for a tow bar are cable tied up inside the rear bumper , what bothers me more is not having a proper rear tow eye to fit my rigid tow bar on if I need to tow someone , can you buy the original bracket with the eye on ? |
24th May 2015 3:57pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7926 |
I would just buy a shackle that will fit through one of those bolt holes - should be plenty strong enough to tow someone with a rope/strap |
24th May 2015 4:48pm |
You can, they're available from Land Rover dealers. if you're planning on fitting a tow bar though, the Westfalia one has the tow eye as part of it. You'll have to remove the bumper to fit the standard bracket with a tow eye anyway, so you may as well get the tow armature for it. |
24th May 2015 6:06pm |
i have a rigid towing bar for towing and the end won't fit through the holes , I don't like towing with a rope as its abut to easy for the person being towed to go into the back of you . I'll look into buying the original tow eye and bracket or I might just make one to bolt onto the bracket that's on the car now |
25th May 2015 12:17am |
