![]() | Home > In Car Electronics (L322) > 2010 - sat nav screen not turning on |
ksskaret Member Since: 27 Oct 2013 Location: Tromsų Posts: 73 ![]() ![]() ![]() |
Have you checked your voltage, mine is doing a lot of "funny" moves if there is a low voltage. Try to charge it over night with a battery charger. Range Rover TdV8 Autobiography MY2010
Might sound daft but have you tried unplugging the DVD , or checked the connections in the boot area ... ====================================
andrew-a Member Since: 07 Sep 2011 Location: Wirral Posts: 70 ![]() ![]() |
Took it to a specialist today and they plugged in the diagnostics. Found no fault!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35490 ![]() ![]() |
not your exact problem but you could try this,
try site sponsor craig, CTC. ... - .- -.
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
You can also try these guys.
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 612 ![]() ![]() ![]() |
stan I'm sure you've heard this but you are the man! ![]() I was just browsing the forum trying to find a solution to my nav rebooting (just started on Friday) and happened across your post. Worked a treat and thankfully will have the radio for the 1800 mile round trip to the highlands this weekend. If I'm ever passing your way I owe you a pint or two. Ed |
Thanks - I have sent them an email but I guess I have to remove it first. How big a job is that? |
Thanks Stan but I can't find them on the list - any link? Thanks |
The top dash cover has a few obvious screws holding it on and then the screen comes out through the top. I've not done it myself, but it doesn't look as bad as it first appears. |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16312 ![]() ![]() ![]() |
Hi, what is it you need sir? How can we help? Drop me a PM and i will sort in the morning sir ![]() |
