Home > Technical (L322) > Air con compression only 9.45volts-SOLVED
Page 3 of 3 <123
Kylerl322
2006 Range Rover Supercharged 4.2 SC V8 Java Black
how about a thread revive ha ha
Kezbo do you still have a working ac system or did you find out you really aren't supposed to have the 9.5V constant? I did the same as you and put in a new ac compressor but in just a month it has burnt up the clutch already and won't engage even when giving it 12-14v.
Weejock said that his system has only a few millivolt across the wires where as you had 9.5V but his was working just fine and I don't think it's do to a bad clutch because yours (kezbo) was still having 9.5V even with the new clutch meaning a good coil.
I am just basically trying to figure out if the 9.5v is causing the clutch to engage half way and burning up the clutch (which I think it is) and if I need to figure out what's causing the 9.5v supply and fix that.
Post #448089 17th Aug 2017 4:59am
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Yes my AC still works nicely.
I found that the compressor clutch wouldn't engage at 9.5v. If you supply 12v using a test wire to yours does the clutch engage (it should be 12v at the clutch when on)?
Have you got pressure in the system? In the end I tested my pressure switch and found that was where the fault lay.
Post #448093 17th Aug 2017 7:47am
Kylerl322
I have supplied 12v and it doesn't engage, I will probably get a new hose piece with the sensor this go around as well though I know it's in ok order but just want to be sure it will stay working once it's working. I get open circuit when I test the coil on the compressor, as in I get no Ohm reading at all which leads me to believe that it is bad, sad considering the compressor is less than a month old.
Post #448138 17th Aug 2017 3:03pm
kezbo1981
Surely the compressor is under warranty?
Post #448148 17th Aug 2017 4:00pm
Kylerl322
yes are they are sending a brand new unit (not even just a reman) I just don't want the 9-10v to burn out the clutch on this one if that's what happened, bot my old original and reman compressor didn't give me an ohm reading at all on the coil which is why I'm thinking the voltage is frying the compressor
Post #448222 18th Aug 2017 6:33am
Page 3 of 3 <123
