![]() | Home > Technical (L322) > Occasional power loss after long drives 4.4 (petrol v8) |
I had similar on a Mini some years back. Turned out to be a blocked breather in the petrol tank. Try releasing the petrol cap after a long drive and listen for the air rushing in. You may be getting a partial vacuum in the tank. |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
if you are talking about engine power loss, then maybe your fuel pump is low on pump pressure. there are a few threads on this, sometimes, it just has no 'pedal power' other times it will (when cranking) -spin over and not start.
heppsen Member Since: 14 Feb 2012 Location: germany Posts: 170 ![]() ![]() ![]() |
most likely fuel pump.
Bstrong Member Since: 11 May 2015 Location: United Kingdom Posts: 5 ![]() ![]() ![]() |
Thanks for all the suggestions guys.
