Home > Technical (L322) > Occasional power loss after long drives 4.4 (petrol v8)
Bstrong
United Kingdom 2004 Range Rover Vogue 4.4 V8 Buckingham Blue
Hi guys,
Anyone ever experience power loss after a long drive? Usually sorts itself out after switching off then back on after a few minutes. Car's a 2004 v8.
Cheers!
Post #327143 11th May 2015 10:20am
mzplcg
I had similar on a Mini some years back. Turned out to be a blocked breather in the petrol tank. Try releasing the petrol cap after a long drive and listen for the air rushing in. You may be getting a partial vacuum in the tank.
Post #327146 11th May 2015 10:31am
johnboyairey
if you are talking about engine power loss, then maybe your fuel pump is low on pump pressure. there are a few threads on this, sometimes, it just has no 'pedal power' other times it will (when cranking) -spin over and not start.
if its electrical power loss, then you are at the mercy of the gremlin virus..
Post #327150 11th May 2015 10:54am
heppsen
Germany 2012 Range Rover Vogue TDV8 Santorini Black
most likely fuel pump.
Thats how they make themselves know to the public... Mr. Green
Sitting in the tank, it is a bit of a job to get at them, but once out you can
fit a new pump into the housing.
You need a Pierburg Pump for BMW/Land Rover part no: 7.50138.00.0
You might even find them at Amazon.
and read this: http://www.fullfatrr.com/forum/topic16152.html
regards
heppsen 2017 MB V-Class
2016 Q7 (gone)
2012 FFRR TDV8
2012 Smart Pulse Turbo
1986 MB W126
1965 LR Series 2A
1961 LR Series 2
Post #327156 11th May 2015 11:42am
Bstrong
Thanks for all the suggestions guys.
I'll go through each possibility and hopefully cure the issue. Thumbs Up
Post #327439 12th May 2015 2:11pm
