![]() | Home > Technical (L322) > TD gearbox failure due to coolant. |
It appears the gearbox oil cooler has corroded from the coolant side of the heat exchanger allowing engine coolant to mix with the gearbox oil thereby reducing its lubricating properties.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1785 ![]() ![]() |
Normally, the cooler is replaced when the gearbox has been repaired.
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 791 ![]() ![]() ![]() |
I replaced mine about 26,000 miles ago ( vehicle has now done 113,000 ) when it appeared to be clogged and was causing transmission probe on ,my 2003 4.4.
As Mickey says above... 100% SHOULD have been replaced 1st time around... Was this work carried out by your mate or by a garage/business? If changed by the latter i would A, be going back to them and asking for there explanation & B, consider their lack of knowledge before considering any future work! |
By a garage. They are quoting the one year, 12,000 warranty condition on the basis that it's over a year and he's done 32,000. They didn't replace the cooler as far as I know. |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
When I had My gearbox rebuilt the garage insisted that the cooler and radiator where changed, also sounds like it's had the wrong type of antifreeze in the engine, might be a sign of things to come......... Fleabay...... quick |
Thing about wrong anti freeze is that surely rad and heater matrix would also suffer the same failure ? |
Err Yes, but the thinnest thing will go first, everything else will follow in time. Do NOT use Methanol based anti freeze, as it reacts with the aluminium and causes it to rapidly corrode. If it's not luminous pink / orange then I would read the label very carefully.
The BMW 4.4 V8 had blue anti freeze in them from the factory. They had aluminium radiators, oil coolers and blocks. I wouldn't have said it's a reason to panic |
littlecub Member Since: 02 Apr 2013 Location: Ulverstone,Tassie Posts: 325 ![]() ![]() ![]() |
Hi Miggit,
Ok so Ethylene glycol comes in Blue too, but I think you'll be hard pushed to find Methanol in any other colour, other than the possibility of green.
PaulM Member Since: 08 Mar 2015 Location: Warwickshire Posts: 190 ![]() ![]() ![]() |
So what if a previous owner has used a cheap antifreeze? You may not know about it, is there anyway to tell? 2004 RR 4.4 V8 Autobiography |
Presuming it would be the wrong colour Paul... If not then its kind of what you pay for when you have your car serviced Paul, anti freeze gets checked for colour, mixture & level in all device types here... |
