Home > Technical (L322) > TD gearbox failure due to coolant.
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
My mates 2003 diesel FFR is back in the garage. Following a series of transmission warnings and refusal go go past 3rd gear, the box has been removed again ( taken out last year and 32,000 miles ago after complete failure due to torque convertor breaking up ). Seems this time the gear box oil has been contaminated after coolant got in to it due to a failure in the gearbox oil cooler. Can any one enlighten me as to what has occurred and how you can guard against this .
Post #326475 7th May 2015 7:26am
It appears the gearbox oil cooler has corroded from the coolant side of the heat exchanger allowing engine coolant to mix with the gearbox oil thereby reducing its lubricating properties.
The only way I can think of to avoid it is to replace the oil cooler as a preventive measure. Not sure how you decide when though.
The corrosion could have been partially caused by the coolant not being up to spec by not having been changed for a number of years.
Expensive outcome for the failure of an inexpensive oil cooler.
Post #326478 7th May 2015 7:43am
Mikey
Normally, the cooler is replaced when the gearbox has been repaired.
Most places wont entertain a warranty claim without a new cooler and pipework...
Post #326480 7th May 2015 7:48am
DaveK
I replaced mine about 26,000 miles ago ( vehicle has now done 113,000 ) when it appeared to be clogged and was causing transmission probe on ,my 2003 4.4.
At what mileage should you replace this part ?
Post #326482 7th May 2015 7:57am
As Mickey says above... 100% SHOULD have been replaced 1st time around... Was this work carried out by your mate or by a garage/business? If changed by the latter i would A, be going back to them and asking for there explanation & B, consider their lack of knowledge before considering any future work! Whistle
We need to change the cooler & pipes & keep proof for our gearbox supplier’s for any future warranty claim! FACT Rolling Eyes
Post #326485 7th May 2015 8:04am
Mikey
Shocked
Something we do agree on Craig Laughing
Post #326500 7th May 2015 9:12am
DaveK
By a garage. They are quoting the one year, 12,000 warranty condition on the basis that it's over a year and he's done 32,000. They didn't replace the cooler as far as I know.
Post #326506 7th May 2015 9:56am
miggit
When I had My gearbox rebuilt the garage insisted that the cooler and radiator where changed, also sounds like it's had the wrong type of antifreeze in the engine, might be a sign of things to come......... Fleabay...... quick Shocked Yesterday I couldn't spell Engineer... Today I are one!
Post #326818 8th May 2015 10:22pm
DaveK
Thing about wrong anti freeze is that surely rad and heater matrix would also suffer the same failure ?
Post #326871 9th May 2015 11:30am
miggit
Err Yes, but the thinnest thing will go first, everything else will follow in time. Do NOT use Methanol based anti freeze, as it reacts with the aluminium and causes it to rapidly corrode. If it's not luminous pink / orange then I would read the label very carefully.
Pink/Orange good
Blue Panic
Green read carefully, no Methanol Yesterday I couldn't spell Engineer... Today I are one!
Post #326887 9th May 2015 12:35pm
Mikey
The BMW 4.4 V8 had blue anti freeze in them from the factory. They had aluminium radiators, oil coolers and blocks. I wouldn't have said it's a reason to panic Thumbs Up
Post #326890 9th May 2015 12:56pm
littlecub
Australia 2003 Range Rover HSE Td6 Epsom Green
Hi Miggit,
The diesel also had blue anti freeze in it from factory.
I changed mine the other month and the coolant that I got from LR is blue. Very Happy
Post #326964 9th May 2015 10:22pm
miggit
Ok so Ethylene glycol comes in Blue too, but I think you'll be hard pushed to find Methanol in any other colour, other than the possibility of green.
But there is no escaping that if you put cheap antifreeze in your system, and you haven't checked the content, there is a real risk of doing severe damage to all the cooling system and the engine its' self. Methanol is a cheap and nasty thing and eats aluminum for breakfast, dinner and tea, cos it can Shocked Yesterday I couldn't spell Engineer... Today I are one!
Post #326966 9th May 2015 10:38pm
PaulM
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
So what if a previous owner has used a cheap antifreeze? You may not know about it, is there anyway to tell? 2004 RR 4.4 V8 Autobiography
Post #327865 14th May 2015 9:20am
Presuming it would be the wrong colour Paul... If not then its kind of what you pay for when you have your car serviced Paul, anti freeze gets checked for colour, mixture & level in all device types here... Thumbs Up
Post #327873 14th May 2015 9:58am
