Home > General > Jump Battery points
Jump Battery points
Having to jump start the small Fiat that i tow behind the Motorhome from the FFRR, what are the best jumping points on it i know where the positive connection on the FFRR body is , but is there one like it for the earth instead of going direct to the battery as it can be a bit of a tight squeeze attaching a jump lead to it ...... Whistle
Post #29335 25th Sep 2010 10:40am
the negative is a nut on the top of the strut and the positive is en-cased in a plastic box right by the strut/bulkhead...i know the FFRR has a hefty battery but its always better to have the doner cars engine running.. ... - .- -.
Post #29336 25th Sep 2010 10:44am
dan_uk_1984
RTFM?
Post #29347 25th Sep 2010 12:52pm
SteveMFr
Site Sponsor
dan_uk_1984 wrote:
RTFM?
ROFL.
Oh, and thanks for changing your avatar, Mick.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #29350 25th Sep 2010 12:59pm
dan_uk_1984 wrote:
RTFM?
Would if i could find the F Censored g thing in the process of major re-decoration and the other half has put it somewhere safe that friggin safe she can't remember ........
@SteveMFr ........ so what was wrong with the avatar !!!!!!!!!!!!!
Post #29358 25th Sep 2010 2:28pm
DeltaC
United Kingdom 2003 Range Rover Vogue 4.4 V8 Buckingham Blue
Mick,
I wouldn't use the RR for jumping anything... If you could, put it on charge. If its a regular thing, could you fit a trickle charger into the wiring system of the Motorhome so it charges the Fiat when you are hooked up to the mains.
The problem with jumping with the first car running is that when the second car starts, you've effectively got two alternators running together and it is not good for them. It probably has less potential for damage if you leave the RR off as the Fiat shouldn't take much to crank...
DC
Post #29387 25th Sep 2010 6:29pm
taken from the AA site.
Step by step
Before connecting any leads make sure the vehicles are the same voltage and that they're parked with their handbrakes on and ignition off. The vehicles must not touch as this can cause sparks or an explosion.
1. Use the red jump lead to connect the positive terminal of the donor vehicle's good battery to the positive terminal of the flat battery.
2. Then use the black lead to connect the negative terminal of the good battery to a suitable earthing point on the engine or chassis of the other vehicle. This earthing point must be away from the battery and fuel system.
3. With both leads connected wait three minutes for the voltages to equalise before starting either engine.
4. Start the engine of the donor car and allow it to run for a minute then, with it still running, start the engine of the other car and leave both running at a fast idle for ten minutes. Do not remove the jump leads while the engines are running as this can cause serious damage to the electronics on either car.
If the jump leads get hot, then avoid a possible fire by switching off both engines and allowing the leads to cool.
5. Turn off the ignition on both cars and then disconnect the leads carefully in the reverse order to the way that they were connected. Be careful not to touch the clips against each other or against the car bodywork.
6. Start the car that had the dead battery using its own battery power. If it won't start this could indicate a more serious problem with the charging/ignition system that will need investigating by a professional.
Post #29389 25th Sep 2010 7:04pm
EDWARD757
2007 Range Rover Vogue SE TDV8 Java Black
If I recall the manual cautions about jump-starting directly from the battery due the pyrotechnic cutoffs on earlier models - post 07(ish) the pyros were changed to a cleverer system that allows some systems to work in a crash.
Kind regards,
Ed '96 Volkswagen Polo 1.4CL - SOLD
'00 Audi A3 1.8T - SOLD
'97 Lotus Esprit V8 - SOLD
'03 BMW M3 - SOLD
'93 Range Rover 3.9 Vogue SE - SOLD
'92 Peugeot 205 GRD - DIED
'99 BMW 540i Touring - SOLD
'94 Peugeot 405 GDRT - SOLD
'00 Peugeot 406 HDI estate - 63mpg! - SOLD
'08 Range Rover TDV8 Vogue SE - SOLD
'11 Skoda Fabia Greenline II - 94.2mpg!- SOLD
'07 E61 BMW 530d msport touring - SOLD
‘20 Tesla Model 3 SR+
‘20 Tesla Model 3 Performance
Post #29392 25th Sep 2010 7:40pm
SteveMFr
Site Sponsor
Hmmm, I dunno, maybe I enjoy looking at RR fronts more than ZOMBIES? Whistle
Laughing Laughing
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #29404 25th Sep 2010 8:50pm
Laughing Laughing it was a statue ........
Anyhow thanks for the info guys , cannot get the Fiat bonnet open to jump start friggin cable snapped , Rolling Eyes Rolling Eyes Rolling Eyes
Post #29406 25th Sep 2010 9:03pm
SteveMFr
Site Sponsor
Fix it again, Tony? Cool
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #29409 25th Sep 2010 10:03pm
Just for fun, try getting the leads mixed up! Lovely smell of melting plastic and red hot glowing metal. The FFRR survived, as did the MX5 Razz
Disclaimer: DO NOT TRY THIS AT HOME (or anywhere else!) .
Post #29778 28th Sep 2010 9:30pm
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
Why not use the engine battery from the motorhome rather than risking expensive damage to the RR's electronics - unless the caravan's battery is also iffy.................... 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #29782 28th Sep 2010 10:32pm
Motorhome too far from the wee fiat , plus too much hassle to get them in position .......
Post #29788 29th Sep 2010 7:14am
stevegt
United Kingdom 2006 Range Rover Autobiography 4.4 V8 Cairns Blue
If you are worried about the RR electronics why not invest in a power pack. About £100 will get you a decent one and for that price you will be able to charge it off of 12V in the motorhome... 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior
Post #29895 29th Sep 2010 10:14pm
