Home > Technical (L322) > 2008 TD gearbox fault
james s
United Kingdom 2008 Range Rover Vogue TDV8 Santorini Black
Very occasionally my My 2008 V8TD had a rough gear change at ow speed. Normally completely smooth but if I have to take off again after a gentle slow down I sometimes get a bit of a ban as it drops into its chose gear,(which is probably first I guess)
Is this a known thing, or do I just need to leave it with the garage?
Thanks James
Post #325241 1st May 2015 6:11am
How many miles has it done? Sounds like it needs an oil and filter change.... Pete
Post #325244 1st May 2015 6:55am
james s
Thanks Pete. 64k. I think well do an oil and filter change anyway as a start point
Post #325260 1st May 2015 8:25am
Good idea James... Thumbs Up
Post #325262 1st May 2015 8:29am
markcaughey
Scotland 2006 Range Rover Vogue 4.4 V8 Buckingham Blue
Sounds like the 2-1 rollout shift wich seems to be an issue on the 6 speed ZF transmission. If you Google that or 2-1 thud etc you will find its talked about on bmw forums as well.
As above I would recommend gearbox service. That solved this problem. For me anyway Thumbs Up Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #325278 1st May 2015 9:10am
james s
Cool thanks chaps. Does it cause damage or is it just a bit annoying? I.e do I need to rush to get it fixed?
Post #325344 1st May 2015 12:44pm
markcaughey
Not sure but don't imagine it will do the box any favours the way it slams into 1st. I found my driving adjusted to avoid it. When you know its coming ie pulling up to a junction etc just be very gentle on the throttle when pulling away and it sometimes won't drop to first but will stay in second or what I also did was put it in manual if your Coming up to a junction or round about. Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #325364 1st May 2015 1:34pm
