Home > Technical (L322) > 2008 TD gearbox fault |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8275 |
How many miles has it done? Sounds like it needs an oil and filter change.... Pete
1st May 2015 6:55am |
james s Member Since: 12 Mar 2015 Location: United Kingdom Posts: 10 |
Thanks Pete. 64k. I think well do an oil and filter change anyway as a start point |
1st May 2015 8:25am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
Good idea James... |
1st May 2015 8:29am |
markcaughey Member Since: 03 Nov 2014 Location: Glasgow Posts: 316 |
Sounds like the 2-1 rollout shift wich seems to be an issue on the 6 speed ZF transmission. If you Google that or 2-1 thud etc you will find its talked about on bmw forums as well.
1st May 2015 9:10am |
Cool thanks chaps. Does it cause damage or is it just a bit annoying? I.e do I need to rush to get it fixed? |
1st May 2015 12:44pm |
Not sure but don't imagine it will do the box any favours the way it slams into 1st. I found my driving adjusted to avoid it. When you know its coming ie pulling up to a junction etc just be very gentle on the throttle when pulling away and it sometimes won't drop to first but will stay in second or what I also did was put it in manual if your Coming up to a junction or round about. Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE ) |
1st May 2015 1:34pm |
