Home > Maintenance & Mods (L322) > Headlight bulbs |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 |
Brought these bulbs are they the best around at the min?
27th Apr 2015 3:17pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
£136.06 ??? Previously..
27th Apr 2015 3:21pm |
6th May 2015 9:34am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35350 |
look good, hope they perform..
6th May 2015 10:04am |
Not sure what height there at as inside was loose before , will a mot beam setter give me the best height to get them you think? _____________________________________________________
6th May 2015 10:33am |
not sure on that because of the FF levelling thingy...i 'upped' mine in small bits with a test run after each adjustment to get the best spread of light. ... - .- -.
6th May 2015 11:35am |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 |
What Stan said... big improvement 2012 5.0L S/C
6th May 2015 3:20pm |
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 |
I can safely say I will not be purchasing them! |
6th May 2015 4:47pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
being as from the factory the bi-xenons are excellent, i'm not sure why you would even need to upgrade the bulbs. |
6th May 2015 4:50pm |
It had odd bulbs in when I got it and a bit of a yellow beam _____________________________________________________
7th May 2015 6:37am |
your from Yorkshire what can we expect _____________________________________________________ Zambezi silver Vogue Se unique |
7th May 2015 6:38am |
Can that be done on the adaptive ones (2011) with high beam assist Stan? The new chariot does seem a bit on the low side.... High Beam assist The answer to a question nobody ever asked. |
7th May 2015 7:52am |
mine are adaptive so no problem there Dom...high beam assist dips the headlight when it senses oncoming headlights so pretty certain that will be ok. ... - .- -.
7th May 2015 8:01am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
High beam assist has NO extra function within the headlamp sir... Electronic gadgetry just takes over the function of your left hand
7th May 2015 8:23am |
