Home > Maintenance & Mods (L322) > Headlight bulbs
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
Headlight bulbs
Brought these bulbs are they the best around at the min?
http://pages.ebay.com/link/?nav=item.view&...1620433960 Philips D3s 42403xv C1 X - Treme Vision Xenon Burner 50% More Light Lamp _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #324635 27th Apr 2015 4:17pm
Shocked Shocked £136.06 ??? Previously..
Post #324637 27th Apr 2015 4:21pm
Scottyav
There 70 to 90 each _____________________________________________________
Post #324655 27th Apr 2015 7:10pm
Scottyav
Arrived today better be good for 140 quid a pair ! _____________________________________________________
Post #326289 6th May 2015 10:34am
look good, hope they perform.. Thumbs Up
i found my headlights were much better when i manually raised them up a bit.. ... - .- -.
Post #326295 6th May 2015 11:04am
Scottyav
Not sure what height there at as inside was loose before , will a mot beam setter give me the best height to get them you think? _____________________________________________________
Post #326303 6th May 2015 11:33am
not sure on that because of the FF levelling thingy...i 'upped' mine in small bits with a test run after each adjustment to get the best spread of light. ... - .- -.
Post #326315 6th May 2015 12:35pm
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
What Stan said... big improvement Thumbs Up 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #326365 6th May 2015 4:20pm
Rangeyman
I can safely say I will not be purchasing them!
Post #326386 6th May 2015 5:47pm
Zirconblue
being as from the factory the bi-xenons are excellent, i'm not sure why you would even need to upgrade the bulbs.
Post #326388 6th May 2015 5:50pm
Scottyav
It had odd bulbs in when I got it and a bit of a yellow beam _____________________________________________________
Post #326472 7th May 2015 7:37am
Scottyav
your from Yorkshire what can we expect Whistle Rolling with laughter _____________________________________________________
Post #326473 7th May 2015 7:38am
mzplcg
Can that be done on the adaptive ones (2011) with high beam assist Stan? The new chariot does seem a bit on the low side....
High Beam assist Twisted Evil The answer to a question nobody ever asked.
Post #326481 7th May 2015 8:52am
mine are adaptive so no problem there Dom...high beam assist dips the headlight when it senses oncoming headlights so pretty certain that will be ok. ... - .- -.
Post #326484 7th May 2015 9:01am
High beam assist has NO extra function within the headlamp sir... Electronic gadgetry just takes over the function of your left hand Thumbs Up
If anyone wishes to adjust their headlamps may i suggest they run into their local MOT test station and ask them to check the height setup on their headlamps and if on the low side, adjust it up Thumbs Up
Not saying that members should or should not adjust their own beam patterns (only they know their own abilities)
i certainly wouldn’t allow just anyone to adjust my headlamps! That’s for sure!!!
Post #326486 7th May 2015 9:23am
