Home > Technical (L322) > Windscreen Wipers Stopped Working!
cropps
England 2002 Range Rover Vogue 4.4 V8 Java Black
Hi, I was going down the M6 on Saturday, on a weekend away, the weather was patchy rain. The wipers were on auto & doing there thing as reqd. Then more rain & less wipers, i tried adjusting the sensitivity first as this sometimes kicks them into life when the delay is too long, no response, tried switching them on, no response. the missus says why are you not clearing the windscreen? Because they won't ****** work says I!!!!
I pulled over on the hard shoulder but they wouldn't work, the washers wouldn't work either. The rain had eased by now, so i carried on, thinking i would get to the next services & check the fuses in a safer place. Driving wasn't too bad with occasional rain just to keep the screen wet. Anyway 15 miles furthewr up the road i tried them again & they started working & have contiued to work ever since!
Anybody had this issue before or any ideas greatly appreciated. Car is 2003 petrol with LPG conversion.
Cheer's
Neil
Post #324622 27th Apr 2015 12:43pm
Prepros123
England 2004 Range Rover Vogue 4.4 V8 Buckingham Blue
Hi
I had this happen as you describe on my previous ff. it only happened once and never reoccurred in the next 6 years of ownership. Hopefully you will be as lucky. Vehicle was a 2002 also lpg though I doubt that is relevant
Regards Alan
Post #324634 27th Apr 2015 4:03pm
le25dse
Norway 2014 Range Rover Vogue TDV6 Loire Blue
If it happens again, it's probably the wiper relay which is a common fault. Do a search and you will find out how to replace it. ----------
2014 tdv6 (ex. 2004 td6, 1997 2.5 dse)
Post #324638 27th Apr 2015 5:20pm
cropps
Thanks, I'll have a look
Post #324716 27th Apr 2015 10:10pm
rar110
It happened once to me about 2 months ago. ______________________________
Post #325058 30th Apr 2015 7:38am
RRPhil
http://www.fullfatrr.com/forum/topic11626.html
Phil
Post #325087 30th Apr 2015 9:33am
