![]() | Home > Maintenance & Mods (L322) > Retrofit an OEM reversing camera to a touch screen? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35630 ![]() ![]() |
tom, i asked a very well informed member whether this is possible and was told that the screen has three connectors, one for tv ,one for the venture cam and one for the reverse camera..so it is possible to connect a reverse camera and use the reversing lights to supply power but the stumbling block is changing the CCF to enable the input. enabling the CCF apparently , is not a dealer option but can be done with a faultmate or maybe autologic... |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 ![]() ![]() ![]() |
Interesting, thanks for the info, I will have to do some more digging around about configuring the CCF, don't think I am up for shelling out �1k for the equipment... I might contact BBS Spy has he seemed to be working on the configuration with the Blackbox. |
no probs mate, if you do happen to figure it out let us know here.. |
wiggs Member Since: 29 May 2010 Location: Manchester Posts: 182 ![]() |
You do need to switch on the camera in the ccf ...i have range rover software running on my nav screen in the discovery 3 and the camera is fully automatic ( when in reverse ) once enabled |
Awesome news, does anyone know the best way to get it programmed without having to buy the coding equipment. I am happy to pay for the service. Tom
theres proberly someone nearer ...but Pete Bell at Bell autos in York has the equiptment
i've managed to get a pic of the back of the screen so you can see the three inputs...[top right]
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1668 ![]() ![]() |
If it helps, see http://www.disco3.co.uk/shop/index.php?act...oductId=34 for cables to fit the SMB sockets on the nav screen |
ahh, so bare wires and chewing gum no good then.. |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2051 ![]() ![]() |
Any one know if they are the same SMB's as used by Nokia? If so I have some right angled ones and coax to suit and can make some leads up for postage costs and forum donation. |
dont think right angle ones will fit in the recess nigel.. |
Stan
just looking at the pic i posted nigel, it has deep recesses so i dont think a right angle will fit in there.. |
