![]() | Home > General (L405) > Red Lights |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
Night time courtesy illumination lights? Like the 322 had in the interior lights |
StevoJD Member Since: 01 Mar 2015 Location: Worcester Posts: 29 ![]() ![]() ![]() |
Possibly, but I don't think so, these turn on and off for no apparent reason......and are not the same as the mood lighting or the small down lights.
Do you have RSE Steve? |
Meaning, the infra red LED's for the rear seat headphones... |
Yes, I have exec rear seating and the meridian system. Is it something to do with that then?? |
Yes Steve, turn on the rear entertainment and they should glow (not as bright as LED's) they transfer the sound to the wireless headphones sir |
Ah, that makes sense, I'll go and test that out.
Your welcome Steve... Let us know if it is what i thought please, for future reference |
Autobiography Member Since: 10 May 2011 Location: UK Posts: 923 ![]() ![]() |
Yes this is the WhiteFire system. On the L322 vehicles with RSE, this was above the central front armrest. The sound is transmitted from the front now to enable the front passenger to wear earphones too which wasn't possible on the L322. |
Ms. Mdx Member Since: 13 Feb 2015 Location: CA Posts: 62 ![]() ![]() ![]() |
I have red lights that glow in that same area, but they are caused by a lightweight object being placed on the passenger front seat causing the passenger airbag to turn off, hence the warning light. Not sure if this is a USA only requirement. Supposed to protect a small person from airbag deployment, but very annoying when it gets triggered by a not so light handbag!!! 2015 RR ATB (Scotia Grey w/Cirrus-Ebony)
