Home > In Car Electronics (L322) > Sat Nav Oddness
tymh
United Kingdom 2008 Range Rover Vogue TDV8 Tonga Green
Sat Nav Oddness
I've got the white text mk 4 DVD sat nav unit in my boot.
I know someone with an updated map dvd, so tried it in my unit - wouldn't read it, but it works fine in his car. It seems to not like DVDs even though it ways "DVD" on the unit!
Has anyone experienced this before? Do I need a "system software" update to be able to read a DVD - my sat nav disk is a CD... Tym
(current) L322 3.6 TDV8 Vogue 2008 Tonga Green
(previous) L322 4.4 LPG Vogue SE 2003
If it sticks, force it. If it breaks, it needs replacing anyway.
Post #319778 26th Mar 2015 2:03pm
pirated discs can be temperamental , if you could get a copy of his or an original then your could try that..
what do yo mean your sat nav disc is a cd? ... - .- -.
Post #319780 26th Mar 2015 2:10pm
tymh
I mean it's a CD not a DVD - capacity 700mb.
Tried burning the data I have to a DVD and it wouldn't read it. Put it on a CD and it was fine... Tym
Post #319785 26th Mar 2015 2:22pm
Confused
if you have the mk4 dvd based unit then surely it will only accept and read dvd's.... ... - .- -.
Post #319788 26th Mar 2015 2:28pm
DMRR
Take a photo ..... post it here Smile Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #319792 26th Mar 2015 2:31pm
He has the old 2003 CD Sat Nav not the newer DVD...
DVD will not work.
Post #319795 26th Mar 2015 2:38pm
tymh
stan wrote:
Confused
DVDs will read CDs but not the other way round.
Photos to follow... have to go out Tym
Post #319798 26th Mar 2015 2:41pm
DVD will not work.
Oops just seen first post about having the DVD unit.... Crying or Very sad
Post #319800 26th Mar 2015 2:43pm
then i think you have to upgrade your dvd unit with the v32 firmware ...( not 100% sure though)
edit, the touchscreen denso dvd disc wont work in your mk4 dvd unit.. ... - .- -.
Post #319805 26th Mar 2015 2:56pm
tymh
It's not the denso disk. It's from a 2002 navtec system
 Tym
Post #319829 26th Mar 2015 4:04pm
Martyn
2013 Range Rover Vogue SE SDV8 Aintree Green
4-1/00 is already the latest software.
The DVD drives can be picky about quality of discs and speed of burn. Was your friends disc a dual layer DVD? 2013 FFRR Vogue SE
Post #319841 26th Mar 2015 4:42pm
tymh
Not sure - I'll have to borrow it again... does it have to be D/L?
I'm going to try an experiment... Going to take my original RR Sat Nav disk and copy it to three disks:
1 - CD
2 - Single Layer DVD
3 - Dual Layer DVD
Will report back later... Tym
Post #319852 26th Mar 2015 5:30pm
Martyn
The latest maps (2015) will only fit on a dual layer unless they've been stripped down. I think one of the last to fit on a single layer is 2011.
What year is your friends disc? 2013 FFRR Vogue SE
Post #319853 26th Mar 2015 5:33pm
tymh
Supposed to be the latest one - so that *may* be 2014...??? Tym
Post #319854 26th Mar 2015 5:34pm
tymh
OK - update and more oddness
I copied the files from my original 2002 disk to another CD, a 4.7GB DVD and an 8.5GB DVD
The CD gave me a message of "incorrect CD/DVD" - i presume this is because I copied the files rather than doing a disk copy.
NEITHER of the DVDs worked the message remained the same on the screen saying no disk inserted. ALSO... the DVD drive in the boot made NO whirring noises AT ALL when the DVDs were inserted;not a murmur. Tym
Post #319857 26th Mar 2015 6:02pm
