Home > General (L405) > Cubby hole in boot?
scanner
United Kingdom 2010 Range Rover Vogue TDV8 Zermatt Silver
Cubby hole in boot?
I've just taken delivery of my MY2013 L405, having had a L322 for a few years. Unlike the 322 the 405 has only one recess in the side of the boot, and doesn't have any fixing lugs for a restraint net. This, AFAIK makes the recess unusable for storing small items.
Am I missing something here? Is there a kit which will allow me to fix some sort of restraint across the front of the recess? 2010 TDV8 Zermat Silver with dirty streaks
2013 L405 3L Vogue SE Corris grey
Post #319399 24th Mar 2015 12:20pm
Emperor Mong
You are right. It is annoying.
I have not found a perfect solution.
I was going to have a box made to go in the recess and fix it with magnetic clasps or velcro. Too much hassle.
I have the flexible boot liner, so I now put a Tupperware box in there but lift the flap on the liner that extends into the recess. Once it is vertical, it tries to flop back into the recess and therefore it effectively stops the box falling over or sliding around.
Another option would be to screw through the rubber liner into a box to anchor it (but fiddling around with disconnecting it from the liner might be tedious).
Post #319401 24th Mar 2015 12:35pm
modbarra
Scotland 2019 Range Rover Autobiography 5.0 V8 Loire Blue
I used the fixings and net from a l322, works fine
Post #319443 24th Mar 2015 5:56pm
NormanP
United Kingdom 2014 Range Rover Vogue TDV6 Aintree Green
I threaded a 5cm broad Velcro strap, about 60 cm long (bought from a hardware store like Homebase) through the air vent grill, one on each side. On the offside it retains a rolled up picnic rug and a soft bag containing odds and ends; the nearside one retains a folding step and folding box in the upright position (just happen to be things I have always found handy to carry). I suspect the grill won’t take a huge weight strapped to it but for that sort of thing it’s fine. Norman
Current LR: L405 Vogue TDV6 (MY 2014) Aintree Green/ Ivory interior
Past LR: L322 Vogue 4.4 V8 (2002); Discovery series1 V8 (1995)
Post #319449 24th Mar 2015 6:24pm
bertie wooster
England 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
If you use the fixing net from the old car what hooks do you fix it to?
Its amazing how Land Rover have improved the FFRR but have forgotten about practicality. Don't get me wrong I love the new car but wish the rear seats would fold down and the boot had nets to stop the crap I carry around from rolling about.
Also,the hidden door compartments are too shallow to get my sunglasses out quickly.The old roof mounted space was so much better for drivers.Rather than having a choice of mood lighting I wish they would have thought things through from a drivers perspective.
Post #319505 24th Mar 2015 11:08pm
jettec
Australia 2013 Range Rover Autobiography TDV8 Fuji White
The hole in the side is for placing a set of golf clubs in club bag. Give it a go its a nice touch if you play golf !
Post #319512 25th Mar 2015 3:10am
scanner
I asked by dealer if I could get a set of fixings like the ones on a 322, and the answer was No! Apparently the 322 fixings attach to the bodywork rather than the lining, so cannot be used on a 405 as there are no holes in the bodyshell.
I will now experiment with four of those spiny things used for sticking to carpet. If it works details to follow 2010 TDV8 Zermat Silver with dirty streaks
Post #319781 26th Mar 2015 3:15pm
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
Is there no way to upgrade to those locking eyelets on the runner rails that they show in the owners manual? The also seem to come with roll out retainers which lock into them to restrain loads? Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #323531 21st Apr 2015 10:21pm
