Home > Off Topic > anyone got a metal lathe? favour please.
johnboyairey
hi, does anyone have use of a metal lathe please? I have a set of twenty sleeved wheelnuts for another (classic) car. the problem I have, is the new nuts I have sourced, the sleeves are just too fat, and need turning down about 1mm. along about 25mm sleeve length. I have a similar threaded 4 inch bolt to set into the chuck, and each nut could be screwed on, and turned down simply. 20 in all to do... I can post etc. along with an old nut to measure etc. I can paypal you etc.
im in south London if it matters.
Very Happy -thanks, -john.
Post #319692 26th Mar 2015 1:21am
