![]() | Home > My Range Rover > 2004 V8 Range Rover in Adriatic Blue - |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8392 ![]() ![]() ![]() |
BMW didn't design the engine to run at that temp, all the earlier BMW's that ran that engine ran at a much lower temp, when they stuck it in the FF, time had moved on and emissions had been tightened up, the cheap fix was to make it run that hot to pass part throttle emissions, it's not good for the engine and certainly not good for all the plastic and electrics under the bonnet, mine feels much more relaxed at a cooler temp as well..... BTW, yours is starting to look very nice, hope you don't hit too many more snags.... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
broly Member Since: 10 Mar 2015 Location: Australia Posts: 41 ![]() ![]() |
yes i have haerd that increasing the running temps can reduce emissions. makes sense. i think i will make that change now. illget the parts. ive put off doing the radiator and now im glad i have. thanks for following up.
well i need help i think. i fixed the resistor and no joy. i removed the resistor and it still wasnt bright like it should be and flashed fast. i plugged it in the known good left side headlight plug and no change. i swapped all the power packs and no change.
still have the stupid indicator issue. just goign to leave it for a while till a cheap headlight comes up on ebay. i tried though, i pulled my old headlight apart, took the wiring out and removed the circuit board, put that one in the oven to test loosening the glue on the lens, melted in into a blob. corrected the temp and put the faulty one in, but couldnt get it apart, so gave up, dont want to stuff it. there are no other cheap ones around right now.
Looking very tidy now, shame about the light.... Pete
thanks mate. it sux, very self conscience making right turns at the moment and people cant see my indicator well. three lefts is better! i like your ride, looks tuff. if it wasnt in the city 24/7 id copy yours.
i was right to fear removing the dash top. Removing was easy apart frpm some vent tabs just snapping off |
well i think the cause is the lh sunroof drain. its not blocked though. ran some water through and passed through easy but observed fresh droplets had formed on the earth point lower left kick panel
well i got the bar on, the gaps at the side are awful. ive left it as it is for now, because i ran out of time and its my daily driver apart from my scooter which has a flat. its going to take some hours to get it right. i think my problem is i reused the old guards and the welding of two front bars into one. if i had thought more about this i should have kept where it met at the sides on the 2004 front bar, and had only the very top grafted on. ideally this really should be done with new gaurds and a new bar to have a easy time.
Took off the 22s and put on some 18s with near new rubber off a disco i picked up for next to nothing and went to beautiful fraser island on the weekend. . rides so much better with 18s, im not putting the 22s back on.
Road Stone Member Since: 08 Mar 2014 Location: Uganda Posts: 227 ![]() ![]() ![]() |
A great thread and thanks for the updates.
forrey Member Since: 24 Jan 2016 Location: alberta Posts: 24 ![]() ![]() ![]() |
how ya getting on with the saxon wheels ? |
ChristianRR Member Since: 22 Mar 2016 Location: Virginia Posts: 1 ![]() ![]() |
Hello! Great looking RR! Update photos? |
