Home > Technical (L322) > how much "play" should there be in side steps?
sawm24
I have the non retractable sidesteps which I presume are factory fitted.
I noticed that when I put weight on the rear part of the step when fastening the kids in the back the step moves very slightly so you can see a tiny bit of daylight between the step and the car.
From a very quick look underneath I can see two strong diaganol arms that look sturdy enough to hold the steps in place but they are towards the middle and front section.
Will there be supporting bolts towards the back that might need tightening? 2010 4.4 tdv8 - black / ivory
Previous bmw 730d, rrs 2.7 se.
Post #318293 16th Mar 2015 6:08pm
Vogue
no movement at all, mine are OEM fitted by main agent - absolutely rock solid - check your nuts 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #318294 16th Mar 2015 6:09pm
Riverstick
Ireland 2015 Range Rover Autobiography SDV8 Santorini Black
"no movement at all, mine are OEM fitted by main agent - absolutely rock solid - check your nuts"
And when you're finished checking your nuts check the mountings underneath Thumbs Up 2008 Range Rover TDV8 435,000kms
2015 Range Rover L405 SDV8 Autobiography
2008 Ford Focus1.6 tdci Titanium DPF deleted
Post #318423 17th Mar 2015 11:42am
Prepros123
England 2004 Range Rover Vogue 4.4 V8 Buckingham Blue
No play atall in mine I would check tightness
Post #318428 17th Mar 2015 12:01pm
As stated above... Are you 100% sure they are OEM sir?
Post #318430 17th Mar 2015 12:14pm
tanertimur
England 2005 Range Rover Vogue Td6 Java Black
Check bolts then check under steps for rust. I recently had to replace my steps as mine had rusted from underneath which caused movement and partially broke.
I actually bought a pair of oem steps from a member on here as some ppl dont like having them on the ffrr. Range rover td6 54 reg touch screen
Post #318955 21st Mar 2015 2:18pm
