Home > Technical (L322) > how much "play" should there be in side steps? |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3751 |
no movement at all, mine are OEM fitted by main agent - absolutely rock solid - check your nuts 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
16th Mar 2015 5:09pm |
Riverstick Member Since: 06 Mar 2014 Location: Cork Posts: 117 |
"no movement at all, mine are OEM fitted by main agent - absolutely rock solid - check your nuts"
17th Mar 2015 10:42am |
Prepros123 Member Since: 28 Sep 2014 Location: Cornwall Posts: 35 |
No play atall in mine I would check tightness |
17th Mar 2015 11:01am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
As stated above... Are you 100% sure they are OEM sir? |
17th Mar 2015 11:14am |
tanertimur Member Since: 17 Sep 2011 Location: London Posts: 90 |
Check bolts then check under steps for rust. I recently had to replace my steps as mine had rusted from underneath which caused movement and partially broke.
21st Mar 2015 1:18pm |
