![]() | Home > General > 5.0 SC or 4.4 TDV8 |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
The broader torque band on the S/C negates the need for an 8 speed. Previous cars:
Hermes Member Since: 07 Nov 2020 Location: Oop north Posts: 108 ![]() ![]() ![]() |
I’m getting a feeling that each camp is extolling the virtues of their respective vehicle choice and, quite rightly, believes they made the right choice.
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
Appj62 is spot on.
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 349 ![]() ![]() ![]() |
Objectively, here's the torque curves and power figures for all three engine variants for 2012.
So basically the diesel feels more relaxed because it develops its power lower down (hence greater torque)?
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
As Blackdog says it very simple , if you want a sophisticated driving experience using the pinnacle in bespoke engine design then buy a 4.4 sdv8 diesel. The wall of torque from tickover mated to the almost limtless tank range is a no brainer for any attractive, intelligent, well balanced person.
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
My answer is there is no wrong answer all variants have benefits and downsides, they are all great in one situation or another and not so in others, when one engine/gearbox isn’t as good as another it’s only by small percentage, not enough to worry about... buy one enjoy and become your mechanics best friend. |
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1057 ![]() ![]() ![]() |
If you want a car you can drive fast and in a spirited way, don’t buy a Range Rover, petrol or diesel; these are big, heavy lumps which suit relaxed cruising over long distances. Choice of fuel is up to how much time you like spending in fuel stations filling up. Both engines are in their way superb and I would happily have either. |
Agreed, if you want to drive quickly, get something else... my problem is, I like to be comfortable some of the time, then occasionally get my foot down.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7916 ![]() ![]() ![]() |
Better have a go in each then. Bear in mind that a car on a forecourt may have sat about a bit, given Covid, and could probably do with a good run to clear it out and it show its best.... Petrol or diesel....
Personally I couldn't afford an L405, considering in Europe a well spec'd 2011 TDV8 sets you back nearly 25k GBP still!
That’s okay... the same points apply to my wallet! ![]() |
