Home > Maintenance & Mods (L322) > 2011 L322 start stop button
Mchoody
United Kingdom 2011 Range Rover Vogue SE TDV8 Orkney Grey
This has developed a hole somehow, i'm guessing a previous owner has jabbed it with something! Although it still works as it should I would like to replace it. Anyone know how they come out? Also need to get hold of a replacement as well if anyone know the part code or correct description. Cheers.
Post #315249 27th Feb 2015 4:27pm
give Dan a shout... ... - .- -.
Post #315253 27th Feb 2015 4:29pm
PM Ducky Dan, then when its been delivered you can see how its held in and work out how you remove it sir... Thumbs Up
From memory its a simple squeak clip Thumbs Up
Post #315360 28th Feb 2015 12:44am
wealy
United Kingdom 2014 Range Rover Vogue SDV8 Luxor
Its easy and there is a post on here of how I did mine. Its about £28 quid from Dan.
Post #316167 4th Mar 2015 4:52pm
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
Mines broken too Sad
Can anyone post the link on how to replace please.
It's a 2012 model I've got - if it makes a difference.
Post #426157 3rd Feb 2017 7:08pm
supershuttle
I've done mine, I got the button off eBay. IIRC its actually pretty simple to replace with the old switch just pulling out of the facia, well levering it out with suitable protection for the facia.
It must be simple because I did it and again IIRC the switch was out and in my hand in a jiffy. Very Happy Geoff
Post #426165 3rd Feb 2017 7:59pm
GAC23
As someone who breaks into a sweat picking up a spanner ...
... just how simple is this to do?
Post #426188 3rd Feb 2017 10:19pm
you can see from this pic where the prongs are ,so it is quite easy,
Post #426191 3rd Feb 2017 10:49pm
supershuttle
Best thing is just to take a look at the existing one and see if you can get it out. The wires are easy long enough so you can still use it when its out. Getting it back in is just a simple and gentle push.
If you can't get it out reach for your wallet and go to a garage. Rolling with laughter Geoff
Post #426206 4th Feb 2017 7:57am
GAC23
That's great. Thank you.
And - next daft question - any suggestions on what I can use to push the clips in with?
Post #426207 4th Feb 2017 7:59am
Geoff Hurst
United Kingdom 2010 Range Rover Vogue SE 4.4 V8 Java Black
And who exactly is Dan???!!!!!
Post #664670 22nd May 2023 9:40am
Dan was our range rover enthusiastic contact at duckworths...sadly he has gone to pastures new.. ... - .- -.
Post #664673 22nd May 2023 10:03am
AJT FF
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
stop start
Hi
Does anyone have a recommended supplier for one as my 2011 has a hole in it?
Post #665323 28th May 2023 6:08pm
Geoff Hurst
I’ve ordered one from China.. I’ll let you know the out etc once it arrives next week
Post #665326 28th May 2023 6:31pm
AJT FF
Thanks
Post #665329 28th May 2023 7:58pm
