Home > Maintenance & Mods (L322) > 2011 L322 start stop button
Mine was a bit scratched, I ordered one from Aliexpress for about £13... it has been working for months and looks and feels just like the original. That's in a 405, I'm sure the 322 is similar...
Link to it if someone wants one...
https://www.aliexpress.com/item/1005001770865983.html Pete
Post #665375 29th May 2023 11:11am
Geoff Hurst
United Kingdom 2010 Range Rover Vogue SE 4.4 V8 Java Black
Well item turned up early, well packed, good replica and fits very well
On eBay :- For Range Rover L322 Ignition Switch Keyless Starter Start Stop Button LR050802
Seller:- wholesale-autouk
Price:- £19
Post #666306 10th Jun 2023 10:53am
AJT FF
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Great. Was it easy to install?
Post #666307 10th Jun 2023 10:54am
Geoff Hurst
Yes, check clip positions on new one, I used smallest 2 flat screwdrivers, gradually easing 1 in while fiddling with the clip with the other, slowly once one was released move to another, once all 3 unclipped, with fingers, hold firmly and pull using screwdrivers to further ease out, changing position every couple off pulls to keep it leveridged equally as not to click back in place, it will eventually pull out. Ensure small pins are perfectly straight and in position, dont over bend or you’re in Censored street!
Post #666310 10th Jun 2023 11:09am
AJT FF
Thanks. What could go wrong!!
Post #666571 14th Jun 2023 8:58am
